It is currently Mon Jul 21, 2025 3:51 pm
 Post subject: mk1 wiper wiring
PostPosted: Fri Jan 25, 2013 3:05 pm
hi all. have a 66 deluxe square body wiper motor which i need to wire to the switch. has a new wiring loom with green, red/green, black/green at the wiper end and red/green black/green, black at switch end.
can i please get some help to what goes where?
thanks
- '74 Clubman Ute project
PostPosted: Fri Jan 25, 2013 4:35 pm
Hope this helps
PostPosted: Fri Jan 25, 2013 4:36 pm
It appears Green goes on top,
 Post subject: Wiper motor wiring.
PostPosted: Fri Jan 25, 2013 5:46 pm
All pins on the switch are numbered. Check the wiring diagram on a decent workshop Manual and it tells you which wire goes on which pin. Is your wiper motor a self park One ?
"Let us remove your "SHORTS"
PostPosted: Fri Jan 25, 2013 5:57 pm
On new looms they seem to add more wiper motors than what was originally on them, self parking I presume... New looms are great to fit.
PostPosted: Fri Jan 25, 2013 6:05 pm
that helps heaps! now i just need a photo of the wiper motor itself too
PostPosted: Fri Jan 25, 2013 6:27 pm
Check out this thread:
http://www.ausmini.com/forums/viewtopic.php?t=71385
'68 Deluxe w/Metro engine
 Post subject: Here we go.
PostPosted: Fri Jan 25, 2013 6:31 pm
WRONG WIPER MOTOR. Read the thread before posting photos and comments. It confused people.
PostPosted: Fri Jan 25, 2013 6:39 pm
Very sorry.
Not trying to mislead.
PostPosted: Fri Jan 25, 2013 6:46 pm
sorry wrong motor.. anyone got a photo of their early motor?
PostPosted: Sat Jan 26, 2013 3:47 pm
I'm away till late Tuesday if no one has done it by then pm me
PostPosted: Sat Jan 26, 2013 4:47 pm
I have a PDF for an Austin Mini 2 speed + Self Park , no idea if its the same as yours sorry as im a mini newbie :-) but your welcome to check it out just pm me your email address if you need it.
Cheers :Bill
PostPosted: Sat Jan 26, 2013 4:57 pm
No wrong this is non self parking being early..
PostPosted: Sat Jan 26, 2013 5:31 pm
PostPosted: Sat Jan 26, 2013 5:51 pm
wiper switch is #23,
wiper motor is #22.
edit- above diagram is for non- parking motor (850), if yours has parking, the wiring is different (12V goes direct to motor from the fuse).
Here's the Deluxe one:
wiper switch is #26,
wiper motor is #25.
