Radius arm pivot pin. https://www.ausmini.com/forums/viewtopic.php?f=2&t=80104 |
Author: | Huelin2008 [ Sat Jan 26, 2013 7:17 pm ] |
Post subject: | Radius arm pivot pin. |
Thanks drmini for helping me get logged in. On the rear radius arm of a 1971 clubman, do the large washers go on the inside of the bracket and subframe or on the outside next the the nut... I think it's the inside but forgot to take a picture of that particular part Thanks |
Author: | Mick [ Sat Jan 26, 2013 7:20 pm ] |
I am assuming you mean the large thick washers with the eccentric groove cut into them? If you do, then they go on the inside against the radius arm with a rubber ring around the outer edge. Groove side inwards. |
Author: | Huelin2008 [ Sat Jan 26, 2013 7:21 pm ] |
Yep that's what I mean, thought so but just checking..... Will get there eventually |
