Primary Gear Bush Replacement https://www.ausmini.com/forums/viewtopic.php?f=2&t=80105 |
Page 1 of 2 |
Author: | Mick [ Sat Jan 26, 2013 7:27 pm ] |
Post subject: | Primary Gear Bush Replacement |
Reaming primary gears top hat bush, what's involved? Can you use a hone or do I need a precision reamer? Also, the rear bush, I can get both standard and floating front bushes it seems for 1275's, but only the rear bush for a small bore. Does this seem correct? Don't be fooled by C-AEA3240, it tells you its 1275 in the description. http://www.minispares.com/search/classi ... 0bush.aspx |
Author: | drmini in aust [ Sat Jan 26, 2013 8:03 pm ] |
Post subject: | Re: Primary Gear Bush Replacement |
Mick wrote: Reaming primary gears top hat bush, what's involved?
Can you use a hone or do I need a precision reamer? Also, the rear bush, I can get both standard and floating front bushes it seems for 1275's, but only the rear bush for a small bore. Does this seem correct? Don't be fooled by C-AEA3240, it tells you its 1275 in the description. http://www.minispares.com/search/classi ... 0bush.aspx Q1. Forget reaming, set it up true in a lathe and bore it to size. The 2 bushes need to be aligned. Q2. Yes the front bush for a 998/1098 seems to be NLA. You could get one made, silicon bronze is what the floating 1275 bushes are, I've been told. I'd find another 998 primary gear, there are heaps about. Up here, anyway. it's 1275 ones that are rarer. |
Author: | Mick [ Sat Jan 26, 2013 8:06 pm ] |
Yeah I suppose I could replace it. When I took the cover off I noticed there was evidence of a small amount of oil getting through the primary gear so I figured I would replace it. I've gone and pushed a new bush into the primary gear after using a burr to remove the old one. It would be a shame however to waste a good part and gear... |
Author: | drmini in aust [ Sat Jan 26, 2013 8:13 pm ] |
If you find a new front bush, sent it and the gear to me and I'll machine it for ya gratis. I owe ya a few favours... ![]() Otherwise, I have a few 998 gears here, can probably fine a good one. BTW the bore clearance is .003" when new, measure yours it may be OK still. |
Author: | Mick [ Sat Jan 26, 2013 8:33 pm ] |
drmini in aust wrote: If you find a new front bush, sent it and the gear to me and I'll machine it for ya gratis.
I owe ya a few favours... ![]() Otherwise, I have a few 998 gears here, can probably fine a good one. BTW the bore clearance is .003" when new, measure yours it may be OK still. Thanks Doc, I might take you up on that but not for gratis. I have a new front bush and have already pushed it in, I'll put it in a postpack and get it to you with a few dollars in it if that is ok... Stand by for a PM. thanks |
Author: | 69k1100 [ Sat Jan 26, 2013 10:04 pm ] |
http://www.calverst.com/articles/Gearbo ... cement.htm http://www.turbominis.co.uk/forums//ind ... t&tid=9065 Could make your own :p |
Author: | drmini in aust [ Sat Jan 26, 2013 10:10 pm ] |
69k1100 wrote: http://www.calverst.com/articles/Gearbox-Primary_gear-bush_replacement.htm
http://www.turbominis.co.uk/forums//ind ... t&tid=9065 Could make your own :p I made a custom bore one years ago for Cody (remember him?) out of solid LG2 leaded bronze bar. I think the swarf produced was 90% of the bar, and it took a while on my Myford bench lathe! ![]() |
Author: | 69k1100 [ Sat Jan 26, 2013 10:23 pm ] |
http://m.alibaba.com/trade/search?SearchText=Bush Again with the links, but I'm sure china could make you a suitable one, just enforce the exact specifications of the material, although you may end up with 100 of them. |
Author: | 69k1100 [ Sun Jan 27, 2013 10:46 pm ] |
Is there demand for these bushes? Could you machine one out of a tophat bush seeing as they're the same size? If it's a sought after part we could organise a group but and get them made overseas (probably much cheaper than they're locally availiable for) |
Author: | sam_1100 [ Sun Jan 27, 2013 11:18 pm ] |
I bought one from a bloke on turbo minis to fit 1275 straight cut primary onto my small bore. Was cheap and easy and there's heaps of info on turbominis about it. |
Author: | drmini in aust [ Mon Jan 28, 2013 10:11 am ] |
69k1100 wrote: Is there demand for these bushes? Could you machine one out of a tophat bush seeing as they're the same size?
If it's a sought after part we could organise a group but and get them made overseas (probably much cheaper than they're locally availiable for) I'd be more inclined to get them made here on a CNC lathe so you have Quality Control of both material and tolerancing (China don't know what that is). As suppliers here have already done with Hi-Los, steering rack inner lock nuts and various other parts. BTW I think your idea of making one from a top hat bush is good. These won't disappear for a while as they are also a 1275 part. |
Author: | GR [ Tue Jan 29, 2013 7:25 pm ] |
Hi Why not just buy a new primary gear from Karcraft $80 problem solved Graham Russell |
Author: | Mick [ Tue Jan 29, 2013 7:43 pm ] |
GR wrote: Hi
Why not just buy a new primary gear from Karcraft $80 problem solved Graham Russell You're kidding right? I thought these things were like 11/32 thousand dollars each when new... |
Author: | GR [ Tue Jan 29, 2013 7:49 pm ] |
Hi Mick You better be quick they only have 2 in stock and i don't think they will last long now Graham Russell |
Author: | Mick [ Tue Jan 29, 2013 8:03 pm ] |
You make a good point considering I only will have 1/2 of the new bushes required anyway.... |
