It is currently Fri Jul 18, 2025 3:57 pm
 Post subject: Van rear door gas struts
PostPosted: Sat Feb 02, 2013 11:08 pm
Has anyone converted their van doors to gas struts?
1962 Traveller with 1275LS engine
PostPosted: Sun Feb 03, 2013 12:05 am
Can't be too hard, people have put struts on bonnets. Wouldn't need to be a big strut at all either.
PostPosted: Sun Feb 03, 2013 7:17 am
The problem I see is that the doors open up 90 degrees. A bonnet opens up to about 45 degrees.
I cant really see the advantage of having struts anyway. :?
WD40'll fix it!
If it don't, use a big hammer!
PostPosted: Sun Feb 03, 2013 10:54 am
positioned correctly, you'd be able to make them pull the door shut as well as push it open
PostPosted: Sun Feb 03, 2013 7:05 pm
The only reason I am considering it is because one of the original stays to hold the door open is missing and I don't want the door to flap about in the wind.
PostPosted: Sun Feb 03, 2013 7:17 pm
Should be plenty of them floating around? I know of a few, just not handy right now.
Users browsing this forum: Bing [Bot] and 96 guests
