Spotlight brackets https://www.ausmini.com/forums/viewtopic.php?f=2&t=80129 |
Author: | keithb [ Mon Jan 28, 2013 3:50 pm ] |
Post subject: | Spotlight brackets |
Can anyone advise how to fit spotlight brackets to a Round nose? These are the typical brackets available across the net. I can't find any info on how the actually attach to he car. Cheers |
Author: | frednutz&co [ Mon Jan 28, 2013 3:54 pm ] |
i have a crossbar welded to my nudge bar on both my vans wit the spots mounted on it . works OK and the light are protected. |
Author: | Harley [ Mon Jan 28, 2013 4:51 pm ] |
Usually some holes have to be drilled in the body somwhere for the brackets to mount too, for example, I had to drill four holes just under the grille behind the bumper. |
Author: | Irish Yobbo [ Mon Jan 28, 2013 10:03 pm ] |
I'm not sure about roundies, but with my clubby I just took off the grill, drilled two holes and made them out of some aluminium bar. They've worked fine for the last 2 years. Just make sure you use some big washers to prevent them from tearing the sheet metal if they get knocked. |
