It is currently Mon Jul 21, 2025 9:13 pm
 Post subject: Crankshaft endfloat!!!
PostPosted: Wed Jan 30, 2013 9:55 pm
Hi all!
Started the fun stuff tonight and immediately hit a snag! installed the crankshaft and when I checked the end float it was 0.039"! Apparently the end float was set up by the machine shop to 0.006"! Measured the thrust washers and the bottom ones were 0.092" and top was 0.095". Something is up! Any ideas?!
Steve
 Post subject: end float
PostPosted: Wed Jan 30, 2013 10:22 pm
Location: MinisintheGong [Somewhere on the South Coast]
Many years ago when i was 18 i had an engine replacement in my 1964 Cooper due to end-float getting so rattly. My first big Mini :(
I hope your get a better answer...
..still waiting for the Italian Job sequel to see if the bus went down :-) :-)
PostPosted: Wed Jan 30, 2013 10:40 pm
Me thinks you've got a std set of thrust washers.
You'll need + .030" over size, which I believe a getting hard to get, to get you into the ball park!
Doc will be on here tomorrow to maybe point in the right direction for finding them.
Cheers Shane
What size engine are you building? Is it std or do you plan to rev it a little.more?
PostPosted: Thu Jan 31, 2013 8:58 am
Std, +.003", and +.030" ACL thrusts for a 1275 are still made here and are NOT hard to get. Contact Karcraft (karcraft.com.au), or Lindsay Seibler (minis.com.au), or Mini King, or minisport.com.au
If you are building a smallbore though you may need to get some thrusts modified (silver soldering shim steel onto the steel backing is one way out).
PostPosted: Thu Jan 31, 2013 6:43 pm
after much fiddling managed to get a 0.004" end float. Is that enough? It's a 1275 bored 40thou with a pretty lumpy cam...not going to be driving it that hard, just the occasional spirited drive! Also...while I'm on the subject, need a slot drive oil pump that'll fit into a cooper s block...will I have to drill and tap the block?! thanks for all the replies!
PostPosted: Thu Jan 31, 2013 6:47 pm
.004" is not enough you want .006" or more. Don't ask how I know this... :cry:
[edit] I'm assuming you checked endfloat with a dial gauge. If you used feeler gauges it probably has a thou or 2 more clearance than you think.
Sand a little off the back (steel side) with a sheet of 180 wet/dry paper and a flat plate or sheet of glass.
Yes you will have to tap 1 hole, the slot drive pumps use only 2 bolts, in a diagonal array.
PostPosted: Thu Jan 31, 2013 8:09 pm
bugger!! ok, excuse my ignorance but can I remove the center main cap with the crank and pistons in place?! I thought 0.004" would be enough end float so assembled the pistons etc.! Thanks again!! Novice engine builder here...would be completely lost without the forums!
PostPosted: Thu Jan 31, 2013 8:19 pm
sure no prob.
make double sure the thrusts fit the right way, bronze faces out <->
PostPosted: Fri Feb 01, 2013 9:12 pm
All sorted!! After a fair bit of trial and error ended up with a 0.006" end float!! All thrusts in the right way! really enjoying the build!! Setting the cam timing next!! Thanks again for the help! Steve
PostPosted: Fri Feb 01, 2013 11:04 pm
re oil pump, yes drill and tap the block plug the old hole, locktight a bolt in there and grind flush
PostPosted: Fri Feb 01, 2013 11:09 pm
I have a sneaking suspicion I didn't do this when I converted my last 1275 to two bolt pumps... Although I am wondering how I got away with it given the bolt hole goes into the water jacket right?
PostPosted: Sat Feb 02, 2013 8:00 am
NVM, the gasket seals it. I always thought it was a blind hole there, because if the bolts are too long they bottom out.
[edit] goes to check Mk2S block...
That hole is blind in this one. But the S pump's top hole isn't.
Last edited by drmini in aust on Sat Feb 02, 2013 9:31 am, edited 3 times in total.
PostPosted: Sat Feb 02, 2013 8:07 am
when i put the air blower in this hole the air went passed inside the block , not sure if was into a water jacket but i pluged it up to be safe.
