It is currently Sun Jul 20, 2025 12:33 pm
PostPosted: Thu Jan 31, 2013 2:20 pm
Guys
Worked on many cars and done may bits, but never taken a mini engine out through the bonnet! So looking for some recommendations on the best methods and steps.
Thanks
PostPosted: Thu Jan 31, 2013 2:27 pm
Doogie has the following article in the howtos:
http://www.ausmini.com/forums/viewtopic.php?t=45377
The auto isnt much different. Just disconnect the selector cable first. This can done from within the car.
The selector cable is normally a pain to disconnect from the gearbox so just leave it.
What are you doing with the auto?
1966 Morris Mini Minor Saloon (Dot) - 1275 Auto - Mongrel
1968 Morris Mini Van (Ivan) - 998 Auto - Mongrel
1968 Morris Mini.Matic (George) - Original
1968 Morris Mini.Matic (Charlie) - Original
PostPosted: Thu Jan 31, 2013 2:49 pm
Because the box is bigger on an auto there will be less clearance for lifting and moving it around, make sure you have something to protect the bodywork.
Remove everything you can too - like alternator and starter motor, radiator if you can.
PostPosted: Thu Jan 31, 2013 3:49 pm
Yeah, Autos are a bit tighter to get in and out. Especially late ones with the park switch on the front.
Brett Nicholson
Greendale (near Ballan) VIC.
1971 Morris Mini Moke
1966 Austin Mini
1965 Morris Mini Traveller
1973 LR Series 3 88
2007 LR Freelander 2
PostPosted: Thu Jan 31, 2013 8:47 pm
So the old trick of lifting the car over the subframe doesn't work?
PostPosted: Thu Jan 31, 2013 9:01 pm
Sure it does. I had a MiniMatic and a hydro Clubby (with 1310S motor)- one day I drained the hydros, lifted both bodies and did a swapsie. Easy peasy...
