Easy steps to removing an auto engine...
https://www.ausmini.com/forums/viewtopic.php?f=2&t=80156
Author:  Blunder [ Thu Jan 31, 2013 2:20 pm ]
Post subject:  Easy steps to removing an auto engine...
Guys
Worked on many cars and done may bits, but never taken a mini engine out through the bonnet! So looking for some recommendations on the best methods and steps.
Thanks
Author:  68AUTO [ Thu Jan 31, 2013 2:27 pm ]
Doogie has the following article in the howtos:
http://www.ausmini.com/forums/viewtopic.php?t=45377
The auto isnt much different. Just disconnect the selector cable first. This can done from within the car.
The selector cable is normally a pain to disconnect from the gearbox so just leave it.
What are you doing with the auto?
Author:  Harley [ Thu Jan 31, 2013 2:49 pm ]
Because the box is bigger on an auto there will be less clearance for lifting and moving it around, make sure you have something to protect the bodywork.
Remove everything you can too - like alternator and starter motor, radiator if you can.
Author:  bnicho [ Thu Jan 31, 2013 3:49 pm ]
Yeah, Autos are a bit tighter to get in and out. Especially late ones with the park switch on the front.
Author:  69k1100 [ Thu Jan 31, 2013 8:47 pm ]
So the old trick of lifting the car over the subframe doesn't work?
Author:  drmini in aust [ Thu Jan 31, 2013 9:01 pm ]
Sure it does. I had a MiniMatic and a hydro Clubby (with 1310S motor)- one day I drained the hydros, lifted both bodies and did a swapsie. Easy peasy...
