Hi,
I was working on rebuilding my Moke's gearbox today (late A+). Everything was going swimmingly until I tightened up the bolts on the third motion shaft retainer. The lower bolt hole that holds the layshaft and reverse shafts in place stripped.
I've already pulled the layshaft and reverse idler shaft out. It looks like I can drill the hole out and heilcoil it back to 5/16 UNF or UNC without too much problem. I will have to cut down the helicoil before fitting though, as the gearbox web is rather thin at this place and I don't want the end of the helicoil hanging out the back and possibly fouling on the reverse idler.
Can anyone see an issue with this?
Thanks,
