Mini with a Spanish compliance plate (here in Oz)? https://www.ausmini.com/forums/viewtopic.php?f=2&t=80211 |
Page 1 of 2 |
Author: | ten_sim [ Sun Feb 03, 2013 7:01 pm ] |
Post subject: | Mini with a Spanish compliance plate (here in Oz)? |
Went to look at a rolling shell here in Townsville... strange thing is it had a compliance plate on the drivers seat mount that was in espanol, did they make minis in Spain or would this have been imported there from the UK? It also had interesting roof sills that I haven't seen before, they had quite large drain hole cut outs in each corner, I'm guessing these were the reason why the sills were in such good condition (no rust at all that I could see). |
Author: | Morris 1100 [ Sun Feb 03, 2013 7:17 pm ] |
They made Mini in Spain. They were made by Authi. |
Author: | Bubbacluby [ Sun Feb 03, 2013 8:31 pm ] |
got pictures? |
Author: | drmini in aust [ Sun Feb 03, 2013 8:42 pm ] |
google Authi Mini... Here's a start, historywise.. http://en.wikipedia.org/wiki/Authi#Name pics- http://www.google.com.au/search?q=authi ... 40&bih=785 [edit] one peculiarity in the driveline of the Authi Mini was they did not use CVs. Instead, they had 2x Hardy Spicer U/Js joined together so as they could turn to way more than the 45° such a single joint could stand. See http://www.aronline.co.uk/blogs/cars/mi ... eas-spain/ Some other cars of the time eg. Renault R4 had a similar arrangement. |
Author: | John Smidt [ Sun Feb 03, 2013 8:58 pm ] |
ALso check them out on Youtube |
Author: | ten_sim [ Sun Feb 03, 2013 9:05 pm ] |
Here are some pics I took... Does this look like an Authi? If so, would that make it 'special-er' perhaps? ![]() image by ten_sim, on Flickr ![]() image by ten_sim, on Flickr ![]() image by ten_sim, on Flickr |
Author: | drmini in aust [ Sun Feb 03, 2013 9:09 pm ] |
Looks like one, the only other Minis that looked similar were the Innocentis made in Italy. Check it against the pics in the link I gave above. |
Author: | John Smidt [ Sun Feb 03, 2013 9:15 pm ] |
I know it is a bit of subject but Is That a 2 door XP in the back ground |
Author: | ten_sim [ Sun Feb 03, 2013 9:30 pm ] |
Not sure mate, he did have a couple of interesting shells in the yard, I think that was a 2 door, not sure of make/model though... The grill on this mini looks like those Authi images I think? Any other distinguishing clues to look for? Would an Authi mini be a pain to work with (particularily if I'm considering an R1 conversion!)? |
Author: | MG Rocket [ Mon Feb 04, 2013 6:52 am ] |
John Smidt wrote: I know it is a bit of subject but Is That a 2 door XP in the back ground
Possibly two of them ... a two tone red and white in one photo and in the other, a cream or primered one. |
Author: | bnicho [ Mon Feb 04, 2013 8:07 am ] |
An Authi is very collectible. ![]() How the heck did that one end up ion Aus? It really deserves to be preserved. You should be able to find someone willing to swap an Aussie or even a Rover shell for that one. Cheers, Brett |
Author: | lmbm [ Mon Feb 04, 2013 10:49 am ] |
Hi it can be one... Authi built minis apart from from obvious cosmetic differences have also very particular details in the engine department: - gearbox casing numbers do not match any of the known BMC numbers ( if i recall they start with an X ) - block to oil filter pipe is different, goes close to the block and below the dizzy. Smart idea as the dizzy vacuum unit never fouls on it - even the standard 998's got forged rockers , similar/same as the S rockers , even the adjusters have same thread as S ones. as Kevin pointed, they did use a kind of Hardy Spicers instead of CV joints, the Slalom racers here in Portugal are fan's of these H.S. ![]() check if your engine has these differences. Cheers Luis |
Author: | ten_sim [ Mon Feb 04, 2013 11:43 am ] |
Quote: Authi built minis apart from from obvious cosmetic differences
Sorry to be stupid, but what would be the obvious differences? I'm thinking the front grill for starters (seems to have a different shape?), anything else? This one doesn't have an engine in it (though there are two engines out of the car that come with it, think they're a 998 and and 1100, maybe. Don't think they're original to the car, could be wrong!) Thanks for your help ![]() |
Author: | lmbm [ Mon Feb 04, 2013 6:07 pm ] |
Quote: Sorry to be stupid, but what would be the obvious differences? I'm thinking the front grill for starters (seems to have a different shape?), anything else?
Hi, The doors, ( door handles, door windows , hinges ), the steering wheel ( yours is not the original one ), the dials ( speedo, oil pressure, water temp ) would have lettering in Spanish... and there are probably more differences.... Cheers Luis |
Author: | Convertible Mini [ Mon Feb 04, 2013 7:30 pm ] |
Post subject: | Spanish Mini |
It should be Left hand drive. |
