Subframe Welding https://www.ausmini.com/forums/viewtopic.php?f=2&t=80216 |
Author: | jubblies [ Sun Feb 03, 2013 10:13 pm ] |
Post subject: | Subframe Welding |
So I'm about to get my subframes to a blaster. I often hear about people welding up the towers on a subframe for added strength. This raises a few questions. Is it only the tower to weld or are there other places? Does the rear subframe need any strengthening? Is it ok to get them welded before blasting? |
Author: | dodge [ Sun Feb 03, 2013 10:25 pm ] |
just stitch weld along the overlaping areas, not apply to much heat into the welds u can do after blasting dont go nuts they dont often break just check the bump stop area its usually cops a beating , u will need a small press to bend them back to flat |
Author: | sam_1100 [ Mon Feb 04, 2013 6:56 am ] |
Yeah at the top of the towers its only been welded as much as was seemingly neccessary, ie not a complete weld. Mine actually managed to crack. Just touch it up with a complete weld around the tower top and you will be all gravy. |
