Oscar wrote:
I put a moulded set in Oscar when I built him up back in '84. They are surviving well, but he's only travelled 50-odd thousand miles since!
The fit is too loose over the centre tunnel forward of the gearstick. Been meaning to pack it up underneath with deadener for the last 30 years...........
Interestingly I reckon I paid about 120 bucks all those years ago, so they haven't gone up very much in price!!
Cheers rodney was a bit unsure with the centre tunnel bit but then i thought well if its moulded it should fit .... i guess its comes down to manufacturing quality.
Lillee wrote:
I got mine from
http://www.trufitcarpets.com.au/Fits well and I used their Resomat product all over the floor and front and rear firewall as well.
Thanks Lillee , whats the quality and fit like ? and are you happy with it ..... oh and what colour did get , standard black ?.
Speedwell Racer wrote:
I used sellys quick grip to glue mine in.
I bought a clip set and later found out you need to drill holes in the floor to rivet one side of the clip to the floor and I wasn't gonna drill rust free floor pans.
The rear section was coated in sound deadening paint then an underlay kit from minis port then the carpet over the top with a dab of quick grip in the corners. Hasn't moved since putting it in.
The front section was coated with sound deadening then underlay and carpet on top but I didn't glue the front section in.
It just sits there perfectly and hasn't moved.
The good thing about not gluing the front was I could pull it up to run wires underneath it for my sound stystem.
I will go the glue way aswell i think as bugger drilling holes
Cheers for the help peeps its greatly appreciated.
Bill
Project Pickles is ALIVE!!!!!
Click Here!
