Can anyone tell me what this is??? https://www.ausmini.com/forums/viewtopic.php?f=2&t=80274 |
Author: | Blunder [ Thu Feb 07, 2013 1:39 am ] |
Post subject: | Can anyone tell me what this is??? |
Was under the rocker cover of my partners engine!? ![]() Thanks |
Author: | 66S [ Thu Feb 07, 2013 5:40 am ] |
It is a rocker shaft set screw, it locates the rocker shaft to the pedestal with the lock-plate. Maybe the lock-plate is missing and it has unscrewed. The shaft has a locating hole so you need to ensure it hasn't moved because oil supply to the rockers could be cut off. Al |
Author: | drmini in aust [ Thu Feb 07, 2013 7:13 am ] |
If there is no lockplate, put Loctite 262 or similar on the thread before fitting. That's what the aftermarket rocker sets do (although they use an Unbrako grubscrew). If you run without it in the rocker shaft can rotate, cutting off oil feed to ALL the rockers. ![]() |
Author: | Blunder [ Thu Feb 07, 2013 9:31 am ] |
Where in the shaft does it go? Had a Quick look and couldn't see any hole for it |
Author: | Blunder [ Thu Feb 07, 2013 9:40 am ] |
All good... Found and refitted along with set plate I had.... Was late last night when I was looking! ![]() |
