GT Oil Cooler https://www.ausmini.com/forums/viewtopic.php?f=2&t=80298 |
Author: | Firefirey [ Sat Feb 09, 2013 6:27 am ] |
Post subject: | GT Oil Cooler |
Hi Is an oil cooler for the Australian Clubman GT the same as a cooper s and did they come from the UK or made in the local market as part of the Australian build rule? I have a part number :ARO9809. Are they the same as UK Mk 1 / Mk 2? |
Author: | drmini in aust [ Sat Feb 09, 2013 8:27 am ] |
My GT had a 13 row Mocal cooler made in UK. Not sure if that was original (or should have been a 9? row) but the coolers on Cooper S and Oz GT were definitely UK made. |
Author: | Bubbacluby [ Sat Feb 09, 2013 9:52 am ] |
I will try and go and check mine later today and get back to you this evening. I have one removed from a car which will be easier to check than the one on my car ![]() |
Author: | John Smidt [ Sat Feb 09, 2013 12:12 pm ] |
Post subject: | Re: GT Oil Cooler |
Firefirey wrote: Hi
Is an oil cooler for the Australian Clubman GT the same as a cooper s and did they come from the UK or made in the local market as part of the Australian build rule? I have a part number :ARO9809. Are they the same as UK Mk 1 / Mk 2? The GT Clubman and the Cooper S Oil Cooler are the same, 13 row The part Number they were sold as ARA221, ARO numbers are Serck part numbers who were the original supplier of the oil cooler Mocal oil cooler kits in the early days I am fairly sure were Serck oil coolers Later on they had there own oil cooler, |
Author: | SuperCooper [ Sat Feb 09, 2013 1:50 pm ] |
Oil coolers are same between S and Gt I think but aren't the Gt hoses longer for Clubman front? |
Author: | John Smidt [ Sat Feb 09, 2013 3:14 pm ] |
SuperCooper wrote: Oil coolers are same between S and Gt I think but aren't the Gt hoses longer for Clubman front?
Yes The hoses and the mounting brackets are different on the round nose and the GT Clubman |
Author: | Bubbacluby [ Sat Feb 09, 2013 3:25 pm ] |
Clubman hoses are cloth covered aeroquip hoses, with a silver tag around them with the part number on it. |
Author: | Mick [ Sat Feb 09, 2013 5:57 pm ] |
Pick up a new Serck oil cooler and remove the top mounting tags and they're almost perfectly identical to the originals (aesthetically anyway). There's a slight difference in the way the sheet metal is pressed. |
Author: | Bubbacluby [ Sat Feb 09, 2013 8:51 pm ] |
ahh forgot to check mine, sorry. Will try to remember for tomorrow |
