gearbox numbers https://www.ausmini.com/forums/viewtopic.php?f=2&t=80303 |
Page 1 of 2 |
Author: | Minute [ Sat Feb 09, 2013 4:20 pm ] |
Post subject: | gearbox numbers |
can anyone tell me what these gearboxes are? 22g1128 22g1832 and what diff should be in them? thanks. |
Author: | Monaco [ Sat Feb 09, 2013 4:30 pm ] |
22G1128 is a remote change 4 synchro, 3.44 diff 22G1832 is a rod change 4 synchro 3.44 diff |
Author: | John Sneddon [ Sat Feb 09, 2013 4:33 pm ] |
Post subject: | Gearboxes |
22G1128 - 4 synchro remote change - diff ratio 3.44 for standard vehicles or 3.65 for Clubman GT 22G1832 - 4 synchro rod change - diff ratio 3.44 |
Author: | TK [ Sat Feb 09, 2013 4:36 pm ] |
"22G1128 - 4 synchro remote change - diff ratio 3.44 for standard vehicles or 3.65 for Clubman GT" 22G1128 pretty sure didn't come out in a Mini K/early Clubman with a 3.44 diff ![]() |
Author: | Minute [ Sat Feb 09, 2013 4:38 pm ] |
is there any combination other than 18/62 that makes a 3.44diff? i need a replacement 3.44 diff with a 62 tooth crownwheel to replace my broken one |
Author: | Monaco [ Sat Feb 09, 2013 4:41 pm ] |
TK wrote: "22G1128 - 4 synchro remote change - diff ratio 3.44 for standard vehicles or 3.65 for Clubman GT"
22G1128 pretty sure didn't come out in a Mini K/early Clubman with a 3.44 diff ![]() Yeah, some early cars had a 3.76 diff, but most are 3.44. |
Author: | TK [ Sat Feb 09, 2013 4:44 pm ] |
OK http://www.ausmini.com/forums/viewtopic ... 8e58c13476 |
Author: | drmini in aust [ Sat Feb 09, 2013 5:40 pm ] |
Monaco wrote: TK wrote: "22G1128 - 4 synchro remote change - diff ratio 3.44 for standard vehicles or 3.65 for Clubman GT" 22G1128 pretty sure didn't come out in a Mini K/early Clubman with a 3.44 diff ![]() Yeah, some early cars had a 3.76 diff, but most are 3.44. I beg to differ, my Mini K parts book lists 3.765 and 3.647 ratios, NOT 3.44. The only 22G1128 boxes I've found to have a 3.44 in stock were Mk2 S and GT. My car has a box I took out of a GT, its diff ratio was 3.44 until I changed it. The UK 1275GT (with way less power than ours) had a 3.647, I'm not aware the Oz GT ever did. |
Author: | Minute [ Sat Feb 09, 2013 8:43 pm ] |
next question. is there any way of telling what mini these boxes came from? |
Author: | drmini in aust [ Sat Feb 09, 2013 9:22 pm ] |
Minute wrote: next question. is there any way of telling what mini these boxes came from?
re 22G1128 boxes- IMO- "If the box has rubber U/Js and is remote shift it is either off a Mini K or an early 1098 Clubby. If it has rubber U/Js and a puddin'stirrer shift, it is out of a van, or a Moke. If it has Hardy Spicer steel U/Js and the cluster gear has 22G1040 stamped on it, it's a Cooper S or Clubby GT". However, 40 years on as it is, things get swapped about, anything is possible. ![]() |
Author: | Minute [ Sat Feb 09, 2013 9:42 pm ] |
thanks doc |
Author: | John Smidt [ Sat Feb 09, 2013 11:42 pm ] |
If it has Hardy Spicer steel U/Js and the cluster gear has 22G927 stamped on it, it's a Moke". But as The Doc says This may have been changed over the Years |
Author: | Scclubman [ Sun Feb 10, 2013 4:37 am ] |
What must I look for to get a higher ratio say 4.11:1 ![]() |
Author: | drmini in aust [ Sun Feb 10, 2013 8:45 am ] |
Scclubman wrote: What must I look for to get a higher ratio say 4.11:1
![]() The 4.13 and 4.26 were used here in bigwheel Mokes and some Morris 1100s. I have a good 4.26 CW/P for sale if you are interested... [edit] You can fit this ratio to any box. see http://www.ausmini.com/forums/viewtopic ... highlight= |
Author: | Scclubman [ Sun Feb 10, 2013 10:37 pm ] |
Thanks Dr. it will be a bit difficult to get it to South Africa but thanks for the info |
