69k1100 wrote:
Really? Do you have some whiz bang Vvt that keeps the valves open when you crank it?
Realistically when you turn the engine over your fighting compression. If the engine is properly sealed (valves seating, spark plugs tight and sealing, no blown gasket and pistons/Rods/crank are good) than its more difficult to turn it over.
Unless your battery is shagged and the omission of the ignition system actually helps the starter.
And how the hell do you turn the engine over with the immobilser on? Doesn't sound very immobile.
Try some "start ya bastard"
I'm not exactly sure about why the ignition is faster with the imobiliser on, but I'd guess that it's because the ignition is firing a few degrees BTDC, and when the engine is just starting up the engine isn't cranking fast enough for the burn to follow the cylinder.
And the imobiliser cuts off the fuel pump and the ignition, not the starter.
