Can i weld a Cast inlet manifold?
https://www.ausmini.com/forums/viewtopic.php?f=2&t=80330
Author:  michaelb [ Mon Feb 11, 2013 7:25 pm ]
Post subject:  Can i weld a Cast inlet manifold?
I have a cast inlet manifold which has been cut off the exhaust outlet and have found a small hole in the area which was cut.
Can I mig weld up the hole or will I stuff up the manifold by blowing a bigger hole into it?
Is areldite maybe an option?
Car has been running OK but I am assuming will go better without th hole :roll:
Author:  TheMiniMan [ Mon Feb 11, 2013 7:28 pm ]
we used to braze them up no problemo
Author:  michaelb [ Mon Feb 11, 2013 7:30 pm ]
Sadly I have sent my gas bottles back due to rental cost :cry:
Author:  drmini in aust [ Mon Feb 11, 2013 7:46 pm ]
Have gas, can braze... :wink:
I now use oxy + LPG, that saves me 1/2 the BOC exorbitant rental.
Author:  Timbo [ Mon Feb 11, 2013 7:49 pm ]
I stuffed one up that I cut years ago and put a hacksaw slit in the wrong spot. I filled it with Selleys Knead it. It lasted for years.
Devcon would do it too.
Author:  Beanie [ Tue Feb 12, 2013 5:42 am ]
Yeah i used Devcon .. sets rock hard just make sure you kneed it into the hole to plug it ...
Could be braze welded , not MIGED , Maybe ARCed if you had the right rods but even then its touch and go ..
Beanie
Author:  66S [ Tue Feb 12, 2013 5:45 am ]
JB Weld would work OK too, do you have it over there?
Al
Author:  Timbo [ Tue Feb 12, 2013 9:51 am ]
You can get it online, but I've never seen it in shops.
Author:  michaelb [ Tue Feb 12, 2013 10:10 am ]
Thanks Guys.
I have some Sellys kneed it so I might give that a try.
I thought about solder but it may have too low a melting point as it is close to the exhaust.
Author:  69k1100 [ Tue Feb 12, 2013 2:35 pm ]
If the metal isn't too thin you could tap the hole and screw in a bolt or grub screw.
Author:  drmini in aust [ Tue Feb 12, 2013 2:54 pm ]
Having cut lots of these manifolds over the years, if there's a hole there it'll be thin as tissue paper.
Bring it over Michael if the glue doesn't work, and I can braze it properly, no problem.
Author:  michaelb [ Tue Feb 12, 2013 3:33 pm ]
Thanks Kevin,
I will have another look at it tonight and make a decision which could involve a drive out west :wink:
Author:  MG Rocket [ Tue Feb 12, 2013 4:18 pm ]
JB Weld or Devcon will work. JB can be got from most hardware stores.
