It is currently Wed Aug 13, 2025 8:57 am
 Post subject: New pistons too high?
PostPosted: Tue Feb 12, 2013 9:24 pm
I have just assembled my 1100 engine with new GR 80+ flat top pistons and they are sticking out above the deck by about 20thou :?
I'm thinking this is too much as the old dished pistons from memory were either level or slightly below the deck?
With the old pistons I think the engine was about 9.5:1 compression as the head is a modified 202 with approx 60thou shaved off the face.
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Tue Feb 12, 2013 9:27 pm
Do you know for sure if the block was ever not machined on top to raise compression with smaller pistons?
PostPosted: Tue Feb 12, 2013 9:34 pm
Block has been decked.
Take the pistons back to GR and he can face them off for you.
Or, I can do them here. :wink:
PostPosted: Tue Feb 12, 2013 9:41 pm
Yes block has been decked but not sure by how much?
Engine number is still visible, although last skim avoided the engine number area.
Yes I would be happier with 25thou skimmed from the top of each piston.
1969 Cooper "S"
1967 Mini Deluxe
Users browsing this forum: fuzzy-hair-man and 264 guests
