Mini 850 su https://www.ausmini.com/forums/viewtopic.php?f=2&t=80337 |
Author: | amancooljat [ Tue Feb 12, 2013 5:21 am ] |
Post subject: | Mini 850 su |
Got a 1965 mini 850 getting a roady and the engin3 keeps flooding I was told by the mechanic to change the su, and he told me to get one off a copper, any advice will be appreciated cheers |
Author: | MrFail [ Tue Feb 12, 2013 5:45 am ] |
It depends what is actually wrong with the carby. You could change it, but it might just need to service it. Did the mechanic give you any more information on what is actually wrong?? Maybe take it to an experienced mini mechanic, they will be able to figure it out for you and give you your options to sort it out. ![]() |
Author: | smac [ Tue Feb 12, 2013 5:45 am ] |
Get a new mechanic. Sorry, a bit glib, but seriously if you're in the position of relying on somebody else to fix it, this guy obviously isn't the one for the job. Firstly, how do you know it's flooding? WHY is it flooding? (if he's saying replace the carb he must have figured out what is wrong). The comment about a cooper carb is just....well....ignorant. |
Author: | bnicho [ Tue Feb 12, 2013 7:14 am ] |
It's probably just the float bowl sticking open or something simple. This is an okay-ish summary of things to look at: http://en.wikipedia.org/wiki/SU_carburetter#Maintenance_of_the_SU_Carburetor You can get genuine parts to fix any SU from SU Midel in Sydney. They are a simple carb to work on. Cheers, |
Author: | drmini in aust [ Tue Feb 12, 2013 7:22 am ] |
An 850's SU is practically the same as a Cooper's LH carb anyway! As said use genuine parts- stay away from FuelMiser SU repair kits, as their main jet's hose is NOT rated for E10 or premium unleaded, they said. It swells shut, as I found out. ![]() |
Author: | adamstuart [ Tue Feb 12, 2013 10:19 am ] |
Post subject: | Re: Mini 850 su |
amancooljat wrote: Got a 1965 mini 850 getting a roady and the engin3 keeps flooding I was told by the mechanic to change the su, and he told me to get one off a copper, any advice will be appreciated cheers
Sounds like your mechanic isn't up to the task, or at least not the best for the task. Where abouts are you located, someone will be able to point you in the direction of a good mechanic in your area |
Author: | amancooljat [ Tue Feb 12, 2013 12:18 pm ] |
When I bought the car I got a heap of parts and the carby that on it is apparently from a 1275 so he said I need to find the original one or get a new one and I cant seem to find it, just needd to know the correct one to get cheers |
Author: | raisto2 [ Tue Feb 12, 2013 12:59 pm ] |
amancooljat wrote: When I bought the car I got a heap of parts and the carby that on it is apparently from a 1275 so he said I need to find the original one or get a new one and I cant seem to find it, just needd to know the correct one to get cheers
HS2 1 1/4", or HS4 1 1/2" Pretty sure they came with the HS2, but the HS4 will do, just need the right manifold connection. happy to be corrected. |
Author: | drmini in aust [ Tue Feb 12, 2013 1:47 pm ] |
850 manuals all had an HS2. But... If you have the HS4 (1-1/2") and manifold I'd keep it, UK 850 automatics used this, it's good for a couple more HP and more torque on an 850 (or 998 or 1098). Just put a kit in it & get it jetted right.. |
Author: | FNQ [ Tue Feb 12, 2013 1:57 pm ] |
Post subject: | jetting |
Page 93 of vizard yellow 3rd edition suggests standard 850 1-1/4 red spring eb needle or blue spring M needle or standard 850 1 1/2 blue spring e3 needle use as a starter for correct jetting Cheers |
Author: | amancooljat [ Tue Feb 12, 2013 8:31 pm ] |
cheers i guess ill try to see whats available |
