It is currently Tue Aug 12, 2025 6:42 pm
PostPosted: Tue Feb 12, 2013 4:12 pm
Hi all 2 questions
1) I know boot lock shafts usually have a code on them stating what FS keycode will fit it. But I have some that appear not to have a code. Has it been peoples experience that ALL boot handle shafts have a code on them, and its just a matter of needing to clean them a bit more to find them
2) I assume the clubman door lock barrels have a code on them as well, but where as I cant find it, as i have searched and cant find it.
Thanks Brenton
PostPosted: Tue Feb 12, 2013 5:15 pm
I must keep hitting the key code jackpot... all of mine are interchangable from car to car, lock to lock. I've even seen a Rover P5B key start a Mini :shock:
PostPosted: Thu Feb 14, 2013 12:36 pm
If you are wanting to key alike and you have a few locks around it is quite simple to pull out the wafers and reorder them to suit your key. I think there may be only 4 different wafers. I have done this. One key to rule them all!
Another thing that happens with old die-cast ignition barrels is the wafers wear grooves in them to the point where you can remove the key while the car is running. This can make it seem like a lot of keys fit.
 Post subject: Mini Keys.
PostPosted: Thu Feb 14, 2013 3:39 pm
You can start most early Minis using a Key from a Corned Beef tin! Works every time.
"Let us remove your "SHORTS"
 Post subject: Re: Mini Keys.
PostPosted: Thu Feb 14, 2013 5:07 pm
And much cheaper to get the next key cut :-)
PostPosted: Thu Feb 14, 2013 5:46 pm
Like Brenton, I'd be interested to know the answers to his original questions.
PostPosted: Thu Feb 14, 2013 6:05 pm
The Mini King
Bubbacluby wrote:
Hi all 2 questions
Thanks Brenton
1)
Not all boot handle shafts have the number stamped on them
You often have to remove the key barrell and the number will be stamped on the barrell
2)
The Key Number is on the barrell Not stamped on the outside It is not hard to remove the barrell on the clubman door lock
PostPosted: Thu Feb 14, 2013 6:14 pm
Underground, overground, wombling free
Hay Brenton you will find the code on the barrel for the door locks
Just pull the retaining spring off the end of the lock…… then pull the pin out…..or let it drop out……..best to do this over gravel so you will never find it again… :lol:
Then pull the inner barrel out……you might have to clean the crud off to see the numbers.......but a good time to really clean the lock.
should be three numbers........well all four inner barrels i have in front of me only have three numbers stamped on them.
The locksmith I use has the standard English codes on his data base so have never had problems getting keys cut.
I think the rear boot lock is the same…….number on the inner barrel….can’t remember seeing it the last time I had one apart……….as the key I had was close and just needed to be filed for one of the wafers to get it working.
I’ll dig out some rear boot locks tomorrow and have a look…….if I can remember where I put them in the shed...... :roll:
Cheers Neil………..
I have a mini because I'm not allowed to play with small thermo nuclear weapons any more. (bloody neighbours you’d think they would be happy that they don’t have to turn a light on when they need to take a leak in the middle of the night)
Users browsing this forum: Bing [Bot] and 270 guests
