It is currently Thu Aug 14, 2025 3:04 pm
 Post subject: MED crank Damper
PostPosted: Tue Feb 12, 2013 10:13 pm
Anyone fitted a MED crank damper?
Did it go on easily or did you have to dress the centre at all?
Mine seems very tight on a few different cranks.
Thanks.
Now with 2 extra ports!
PostPosted: Wed Feb 13, 2013 7:38 am
Mine fitted OK after I dressed a few burrs off the crank with 180 wet/dry.
It's on my 1412 stroker.
PostPosted: Wed Feb 13, 2013 9:04 am
Cheers Doc, will look at cleaning up more and see how it sits.
Thanks.
PostPosted: Wed Feb 13, 2013 10:43 am
I had similar issues when fitting my Romac damper.
It's a real bugger hand linishing in situ :x
PostPosted: Wed Feb 13, 2013 10:57 am
yeah we use the MED ones & they`re fine
wev`e also used the Romacs & they`re the same
they nearly all need a little dressing up,, , same as the cranks do
it only takes a tiny bruise or burr , or sdimply a little tight
i`d rather dress one down to make it fit nice than have a loose one
PostPosted: Wed Feb 13, 2013 12:19 pm
Yep good call MiniMan.
Thanks for the replys guys!
PostPosted: Wed Feb 13, 2013 8:29 pm
Mine fitted without any needing attention, but Spiro had just given the crank journals, nose and tail a polish so the crank was actually better than most.
michael
PostPosted: Wed Feb 13, 2013 9:17 pm
Same as above, a little clean up on the crank and it is a snug fit. Mine came with a new cnc crank bolt which caused a little angst. The standard bolt screwed in and out with fingers, the new one was tight after a half a turn. Took it to an engineering shop to confirm if the thread was correct, which it was, but apparently it may have been fractionly under cut compared to the original bolt. Buffed the crap out off the thread on my bench grinder and thoroughly cleaned the thread in the crank with a small s/s wire brush ( I don't have the the Crank tap). Now screws in, but still with a little resistence.
Dalmeny
PostPosted: Wed Feb 13, 2013 9:29 pm
I bought the correct tap for crank thread from minisplus. It had left over bolt thread in it. Needed a good chase through and now the MED bolt goes sweet.
PostPosted: Thu Feb 14, 2013 8:05 am
Often a crank gets dried Loctite left in it, which can make the bolt feel a bit tight.
I ground 4 lengthwise grooves in an old 850 flywheel bolt to make a poor man's tap. Works fine for this, also cleans out wasp nests etc from cranks kept `in storage' under peoples houses.. :oops:
Users browsing this forum: Bing [Bot], crisonic and 180 guests
