overheating
https://www.ausmini.com/forums/viewtopic.php?f=2&t=80364
Author:  womble99 [ Thu Feb 14, 2013 6:48 pm ]
Post subject:  overheating
Grrr,
so why does a mini choose to develop faults as soon as you get it registered :x
I now have an overheating problem where the temp will go up dramatically after a few klms. The radiator is bubbling once I stop and I also get some coolant boiling out from under the thermostat cover.....
Guess I will have to pull the radiator out again and replace the thermostat gasket. I hope this is a simple fix :roll: :roll:
CJ
Author:  Harley [ Thu Feb 14, 2013 6:53 pm ]
New thermostat, flush radiator.
Author:  MiniBill [ Thu Feb 14, 2013 6:59 pm ]
Post subject:  Re: overheating
womble99 wrote:
Grrr,
CJ
Damn that sucks but at least it was after you got your rego ........ hopefully its just the thermostat/thermostat gasket or just a hose that needs tightening now she's bedded in or just needs a good flush while the motor is running to get any air locks out.
Just pull the thermostat and run her around the block a couple of times if she doesnt heat up , just replace the thermostat .
Other than than that the only things that come to mind are head gasket or timing.
Author:  womble99 [ Thu Feb 14, 2013 7:14 pm ]
I have just flushed the radiator ad checked the thermostat before rego :( will replace it though just on spec.
Might check the rad cap too, what is the correct part no for a system without an overflow bottle?
Author:  Convertible Mini [ Thu Feb 14, 2013 7:34 pm ]
Post subject:  Play up and develop faults ?
It only happens if you use them! Parked and neglected they are fine.
Author:  Lillee [ Thu Feb 14, 2013 7:43 pm ]
There is only two types really. Long neck cap and short neck cap. The bottom rubber seal should touch slightly on the lip before screwing it in. If its not touching its too short, if you have to push the spring down with great force it'd too long.
I suggest you have a look at the water pump too... It may be now rusty and no longer moving much water....
Author:  womble99 [ Thu Feb 14, 2013 7:49 pm ]
Had the water pump out, it looked pretty good so we didn't replace it. Starting to think I should have replaced everything regardless of condition..............
Holy crap was just looking at rad caps, there is 100's of teh buggers available :o What pressure should a mini cap be? 3,4,7,10,13 psi?
Author:  Lillee [ Thu Feb 14, 2013 8:01 pm ]
Firstly, disregard all parts that aren't mini related.
http://www.minis.com.au/minis/catalog/i ... 9e7aafe653
There are only 3 here, yours is probably the middle one for $9.90 unless you have a late model, fandango radiator
Author:  Bubbacluby [ Thu Feb 14, 2013 8:12 pm ]
I was goign to say there are many different poundages for caps.
I think it is around 12 or 13pound pressure is original for mini, Someone will confirm or deny it. If not I will check mine in the morning :wink:
Author:  sam_1100 [ Fri Feb 15, 2013 7:45 am ]
Was it coming out the radiator overflow?
Mine did that...and then coolant also decided to come out shortly after through the head gasket :shock:
Author:  peterb [ Fri Feb 15, 2013 9:55 am ]
Just a thought regarding caps. Most are available as a recovery system type as well. Grab one of them and put overflow into bottle secured somewhere, works great.
Author:  womble99 [ Fri Feb 15, 2013 2:40 pm ]
Ouch Sam, that doesn't sound like fun to fix. What was the final prognosis?
Author:  Lillee [ Fri Feb 15, 2013 2:48 pm ]
A Russell Engineering head was needed 8) :P
Author:  womble99 [ Fri Feb 15, 2013 3:05 pm ]
Oooh don't say things like that, the boss won't like hearing it :( especially when I might be faced with a similar problem............
Author:  sam_1100 [ Fri Feb 15, 2013 5:29 pm ]
Well I could pretty much scoop the rust out of my head
:shock:
Picked up a second hand 202 and dropped it off at GRs door!
The Main thing I did though was new radiator, thermostat, housing, pipes, fan though, haven't had me an issue since!
