Kennomini wrote:
Is it true that large journal cranks are more prone to brake if they receive a thrashing (compared to small journals) due to the extra weight they have to throw around
Then is the Lrg J crank stronger in std form or stroked
Big journal crank is heavy, and has very poor counterweighting, worse than the small journal ones. This can be improved by wedging it but it costs $$$.
This may not prevent cracking but it does reduce radial load and uneven wear on the main journals.
There is some evidence here in Oz to suggest that yes, they are more crack prone than small journal ones, but that this can be improved if you grind the journals down to 1.625" (whether you stroke, destroke, or keep stock stroke..) The weight of the damned heavy lumpy cap rods the 12G1505 cranks come with doesn't help.
DrMini- 1970 wasaMatic 1360, Mk1S crank, 86.6HP (ATW) =~125 @ crank, 45 Dellorto (38 chokes), RE282 sprint cam, 1.5 rockers, 11.0:1 C/R.
