Difference between 4 pole and 3 pole solenoids? https://www.ausmini.com/forums/viewtopic.php?f=2&t=80431 |
Author: | Angusdog [ Fri Feb 22, 2013 1:18 pm ] |
Post subject: | Difference between 4 pole and 3 pole solenoids? |
Hi, I bought a 4 pole solenoid (Minispares item) and looking at the Estate now, it has a 3 pole (which I'm assuming to be knackered due to starting problems) solenoid. It'll be running a metro engine. What's the difference? What's the extra pole for and can I just ignore it? TIA, Simon. |
Author: | Panthersteve [ Fri Feb 22, 2013 2:32 pm ] |
The difference is 1 pole ![]() ![]() ![]() ![]() |
Author: | Angusdog [ Fri Feb 22, 2013 2:57 pm ] |
![]() Don't make me open it... ![]() |
Author: | Mick [ Fri Feb 22, 2013 4:19 pm ] |
It means you have an extra terminal you can get a switched 12 volt out of when you turn it on. So you have 4 outputs in all instead of 3. |
