Disc Brake Drive Flange Seals
https://www.ausmini.com/forums/viewtopic.php?f=2&t=80447
Author:  Mick [ Sat Feb 23, 2013 4:13 pm ]
Post subject:  Disc Brake Drive Flange Seals
After taking apart an ancient set of Cooper Discs, I noticed there were two different seal types used.
One is the usual seal, with the sealing edge running on the drive flange.
The second type uses a stranger set up to me. The seal has a metal insert (pictured) pressed into a brass ring the hub which runs outside a metal ring pressed onto the drive flange. Can anyone tell me about this seal? Is this a long forgotten original style of seal?
Author:  TheMiniMan [ Sat Feb 23, 2013 4:50 pm ]
looks like the std issue seal "spacer" to me
drummy brakes have it too
Author:  Mick [ Sat Feb 23, 2013 5:23 pm ]
Ok, I did a bit of a search and looked on Minisport for the sealing ring. I see its just an insert which sits against the drive flange. Obviously the seal runs on the outside of the ring.
Its clear now.
I haven't played with front drum CVs since the mid nineties!
Author:  John Smidt [ Sat Feb 23, 2013 7:28 pm ]
Its clear now.
In the photo at least one of them is fairly worn, and I would advise replacing it as
This helps set the pre load on Your bearings
Also Your drive flange has bad wear marks where the bearings are fitted You will have to remedy that for sure
Author:  Mick [ Sat Feb 23, 2013 7:32 pm ]
Thanks John, yes they are. So is the drive flange! I've found another pair of flanges however in great shape amongst my spares.
I reckon I will stop in on my way to Canberra next Friday and pick a pairof seals up with some bearing kits as well.
Have you got them in stock?
Author:  John Smidt [ Sat Feb 23, 2013 7:35 pm ]
Mick wrote:
Thanks John, yes they are. Not expensive either. I reckon I will stop in on my way to Canberra next Friday and pick a pair up with some bearing kits as well.
I have the spacers and the bearings but I am not sure if I have any drive flanges
Author:  Mick [ Sat Feb 23, 2013 7:44 pm ]
They will be fine, as I said I found a pair of good flanges amongst my junk.
See you Friday.
Author:  slacko [ Sat Feb 23, 2013 7:50 pm ]
If you are going to Johhs after lunch time , I will try and be there to catch up and have a chat with you Mick
Mark
Author:  Mick [ Sat Feb 23, 2013 9:01 pm ]
Mark
Sure will, if I drop my responsibilities and leave people hanging efficiently enough I should be outta work by one o'clock.
