It is currently Wed Aug 13, 2025 2:30 pm
PostPosted: Sun Feb 24, 2013 9:39 am
I have a 1971 clubman which I have just swapped the front brakes from drum to discs. I have changed the drive shaft ends to disc type, fitted new disc hubs and bearings. The issue I am having now is that when the wheel is put back on, I can wobble the wheel top to bottom. I can see the disc hitting on the steering arm on top of the hub. Any clues as to what this might be as I am hesitant to drive it in this condition.
Richard
PostPosted: Sun Feb 24, 2013 9:47 am
yes do not drive your mini like this
the problem can be related to a few things
sometimes the disc will hit the steering arm before the bearings are tight (big center nut)
sometimes the bearing spacer & bearings are not quite set-up properly (would need to see it apart myself to know for sure what you`ve done)
sometimes the 4x screws that hold the disc to the drive flange are too long & hit the hub before the bearings are tight
etc etc etc
i`d suggest you have someone experienced come around & rip them back off for an inspection
Matt
PostPosted: Sun Feb 24, 2013 9:52 am
Sounds like bearings don't have enough preload
Have a look in the "How to section" page 2 , under timkin tapered wheel bearings
by Dr mini , This may help explain the importance of preload and torque
Users browsing this forum: No registered users and 199 guests
