is this normal ? https://www.ausmini.com/forums/viewtopic.php?f=2&t=80450 |
Author: | _666_ [ Sat Feb 23, 2013 5:23 pm ] |
Post subject: | is this normal ? |
i was about to wire wheel the top arms i pulled off the moke when i noticed that oen had a metal square welded onto it.. is this normal ? ![]() |
Author: | peterb [ Sat Feb 23, 2013 7:28 pm ] |
I think mokes have them |
Author: | 9YaTaH [ Sat Feb 23, 2013 7:36 pm ] |
You are gunna be in deep, deep trouble if you start wire wheeling there ![]() ![]() |
Author: | _666_ [ Sat Feb 23, 2013 7:52 pm ] |
9YaTaH wrote: You are gunna be in deep, deep trouble if you start wire wheeling there
![]() ![]() and why is that ? |
Author: | Kennomini [ Sat Feb 23, 2013 8:25 pm ] |
_666_ wrote: 9YaTaH wrote: You are gunna be in deep, deep trouble if you start wire wheeling there ![]() ![]() and why is that ? It looks like it's inside a house because of the tiled floor. |
Author: | 9YaTaH [ Sun Feb 24, 2013 9:36 am ] |
Yep...don't wire wheel in the kitchen! ![]() |
Author: | Mokesta [ Sun Feb 24, 2013 11:06 am ] |
Yes, late mokes have those square blocks welded on. Many fall off as the small welds crack. I don't run them on my moke as I set the ride height lower than standard. M |
Author: | willy [ Sun Feb 24, 2013 3:23 pm ] |
Mokesta wrote: Yes, late mokes have those square blocks welded on. Many fall off as the small welds crack. I don't run them on my moke as I set the ride height lower than standard.
M Same. And my bump stops are modified also. I have about 10mm (maybe less... actually definitely less) of travel between my bump stop and the top arm. |
