It is currently Sun Aug 17, 2025 3:34 am
 Post subject: Radiator type
PostPosted: Sun Feb 24, 2013 7:00 pm
Hi ausminiers!
I have a question about radiator types. I recently purchased a replacement alloy radiator only to discover it was a different type to my existing one (I had no idea there were more than one type, being the newb that I am).
Image Image
To change over to the new one, am I correct in assuming that I need only change the thermostat housing and top and bottom radiator hoses to suit? Or is there a good reason I should stay with the older radiator type?
Many thanks,
Ben
'77 Leyland Mini Van
PostPosted: Sun Feb 24, 2013 7:05 pm
The old radiator is 1978? The alloy one fits pre 78.
Sure a change of thermostat housing and hoses will fit if you don't have an air pump.
PostPosted: Sun Feb 24, 2013 7:07 pm
High heel ninja
The radiator on the left is from a 77/78 model mini with a reverse thermostat, the one on the right is a front pointing thermostat which suits any other mini apart from a 77/78 model, easy solution is to change the thermostat husing to a front point type.
Doogie
PostPosted: Sun Feb 24, 2013 7:19 pm
It is a '77 with an air pump, so that means that the forward facing thermostat radiator wont work then?
There must be a way around buying a new radiator. What if I extend the heater hose and reverse the bottom radiator hose to have the connection on the bottom of the hose?
PostPosted: Sun Feb 24, 2013 8:09 pm
Actually, I had no idea what I was talking about. There is no air pump. Disregard the previous post, please. :lol:
Thanks Doogie and TK for your advice!
PostPosted: Sun Feb 24, 2013 8:17 pm
The Mini King
I would check the thermo Housing in the photo
PostPosted: Sun Feb 24, 2013 8:53 pm
yeah it looks like an early housing to me too John
& you may need to stuff with the top radiator bracket too
PostPosted: Sun Feb 24, 2013 9:13 pm
Thanks, John and Matt! I'll see how the bracket lines up once I get it all in! I assume it's not too different?
PostPosted: Sun Feb 24, 2013 9:23 pm
Im sure your Right Matt.
I remember when i changed the radiator on my 78 mini i had to change the top radiator bracket as the holes were in the wrong spot.
Users browsing this forum: No registered users and 421 guests
