diff carrier good and bad https://www.ausmini.com/forums/viewtopic.php?f=2&t=80488 |
Author: | my1293 [ Tue Feb 26, 2013 12:58 am ] |
Post subject: | diff carrier good and bad |
howdy, could some give me examples of both a good diff carrier and a bad one mine behind the thrust washer looks a little bad ,,has a very small lip but it aint too bad |
Author: | TheMiniMan [ Tue Feb 26, 2013 8:29 am ] |
you can get by with a little bad,,, a small lip isn`t really what you want but if you don`t have a better one then have an ask around to see if you can find a better one, but if all else fails then use what you have however, the later A+ diffs are a better bet these days as the thrust washers have a "tang" (yes a bitter taste ![]() so you can use the A+ carrier & thrusts ,,, or,,, use an early diff carrier & grind the space for the Tangs into them & use the A+ thrusts with the early modified carrier |
Author: | John Smidt [ Tue Feb 26, 2013 12:08 pm ] |
TheMiniMan wrote: you can get by with a little bad,,, a small lip isn`t really what you want but if you don`t have a better one then have an ask around to see if you can find a better one, but if all else fails then use what you have
however, the later A+ diffs are a better bet these days as the thrust washers have a "tang" (yes a bitter taste ![]() so you can use the A+ carrier & thrusts ,,, or,,, use an early diff carrier & grind the space for the Tangs into them & use the A+ thrusts with the early modified carrier AS always Good advice I would add if You are able to find one that has red oxide colour painted on it You will find it to be in better condition than most of the others, They are rare however |
Author: | drmini in aust [ Tue Feb 26, 2013 12:13 pm ] |
John Smidt wrote: AS always Good advice I would add if You are able to find one that has red oxide colour painted on it You will find it to be in better condition than most of the others, They are rare however These were the ones made by Borg Warner in Australia. used in Morris 1100 etc. |
