Brake assembly weight: 4-pot alloy https://www.ausmini.com/forums/viewtopic.php?f=2&t=80517 |
Author: | Harley [ Thu Feb 28, 2013 8:25 pm ] |
Post subject: | Brake assembly weight: 4-pot alloy |
Does anyone here know the weight of the now fairly common alloy 4-pot brake setups? If not the whole setup, just the weight of any individual parts will help me compare it with 8.4s, metros, etc. Main parts of interest: the alloy caliper and the vented disc, I can work the rest out if need be. Thanks. ![]() |
Author: | Mokesta [ Thu Feb 28, 2013 9:19 pm ] |
I have a few different callipers here and some discs. If you can wait till the weekend I can weigh them. M |
Author: | Harley [ Thu Feb 28, 2013 9:20 pm ] |
Yep, that'd be great, thanks. ![]() |
Author: | _666_ [ Fri Mar 01, 2013 8:12 pm ] |
ive got a brand spanking set of 4 pots but no scales.. |
Author: | Harley [ Fri Mar 01, 2013 8:57 pm ] |
Bugger. Free tip for those wanting cheap, accurate scales - you can get digital ones on ebay that read upto 40kg in 20g increments for $10 or less. Check the fishing section. ![]() |
Author: | Mokesta [ Sat Mar 02, 2013 2:32 pm ] |
Ok I have weighed the following: 8.4 inch solid disc and drive flange with screws and studs 4154 grammes 8.4 inch vented version of above with metro drive flanges machined to suit mini 5284 g 7.5 inch solid disc and drive flange with screws and studs (cooper s) 3786 g 4-pot alloy minispares UK calliper to suit 7.5" cooper s with pads clips etc 2145 g 8.5 inch 4-pot metro turbo iron vented disc calliper with pads clips etc 3451 g Pics to follow. M |
Author: | Mokesta [ Sat Mar 02, 2013 2:37 pm ] |
The metro turbo 4 pots are for vented but they would be a fraction lighter if the calliper half spacers were removed to suit solid discs. The metro drive flanges have has the big castellations machined off the wheel mounting face but the large outside diameter has not been trimmed down. I have a pair of cooper s 2-pot iron callipers for 7.5" solid discs but they are on a car so I can't weigh them. M |
Author: | Harley [ Sat Mar 02, 2013 3:31 pm ] |
That is more than enough info for me. Thanks for taking the time to do that Mokesta. ![]() |
Author: | Wombat [ Sat Mar 02, 2013 5:30 pm ] |
Yeah thanks - helps me also ![]() |
Author: | Mokesta [ Sat Mar 02, 2013 8:26 pm ] |
Here are the pics: ![]() ![]() ![]() The scales max out at 5kg so I had to split the metro vented disc from drive flange. ![]() ![]() ![]() M |
