This all I need to go drums to Disc https://www.ausmini.com/forums/viewtopic.php?f=2&t=80537 |
Author: | Wombat [ Sat Mar 02, 2013 12:23 pm ] |
Post subject: | This all I need to go drums to Disc |
10" wheels per other post http://www.minisport.com/mini-spare-parts/info_MS2680GEN.html |
Author: | 123grosso [ Sat Mar 02, 2013 12:28 pm ] |
You also need different brake hoses for the front and a different wheel cyliner for the rear drums, i think that is all |
Author: | MrFail [ Sat Mar 02, 2013 12:28 pm ] |
It's probably worth getting a couple of new brake hoses while you are replacing everything. That's what I would do anyway. ![]() |
Author: | Wombat [ Sat Mar 02, 2013 12:34 pm ] |
Is it worth spending the money ? Are twin leading shoes as good as 7.5" discs? I really want to keep the 10" wheels and no flares so are there better options with this configuration? |
Author: | Kennomini [ Sat Mar 02, 2013 2:26 pm ] |
Depending on your wheels you can fit discs without flairs, I have 10x5 LS contessa. Drums will need weekly adjusting to keep them competitive with discs but then you'll still have to deal with drums tendency to fade with heat, yes discs fade but not as bad as drums. |
Author: | MG Rocket [ Sat Mar 02, 2013 3:21 pm ] |
Also any small imbalance from left to right in adjustment or wear does have a significant effect on the brakes pulling to one side. I know from dramatic experience with an EH, also a 6 cylinder ZB Fairlane and a Daihatsu Handyvan. Twin leading shoes do have a self servo effect but a least discs are immune from pulling to one side ...and think of the maintenance....give me discs anyday. |
Author: | drmini in aust [ Sat Mar 02, 2013 6:22 pm ] |
Wombat wrote: Is it worth spending the money ? Are twin leading shoes as good as 7.5" discs? I really want to keep the 10" wheels and no flares so are there better options with this configuration?
Nothing really wrong with drum brakes except you are under there regularly to adjust the buggers. 2 L/S brakes stop as well as discs, ONCE. It is all downhill from there as the brakes heat up. Discs self adjust, and are way more fade resistant. If you don't want flares find some Cooper S wheels, or LS offset Contessas. A Mk1 S was legal without flares, except in South Oz. |
