It is currently Wed Jul 02, 2025 8:59 am
 Post subject: 12g 949 1275 block id
PostPosted: Fri Mar 01, 2013 8:14 pm
Is this block number related to inline 1275 motor?
http://www.gumtree.com.au/s-ad/north-ward/engine-engine-parts-transmission/mini-1275-block/1014362193
PostPosted: Fri Mar 01, 2013 8:25 pm
It's just a thin flange 1275 block. Could be either an 1100S or an MG Midget. Same casting number.
An inline block will work in a Mini. The only mod is to machine the rear main bearing cap's oil return off so it's flat like a Mini one. Of course you need a transverse 1275 crank to use in it.
I'd grab it for $200 if you need a block.
PostPosted: Sat Mar 02, 2013 7:21 am
Looking at the Photo, the fact that it has those 2 Short Studs in the Sump rail indicate that it is more likeky to be from an 1100S (1275) originally.
Dave
PostPosted: Sat Mar 02, 2013 4:02 pm
thank you - good eyes there.
