Window winder jammed....any easy fix?
https://www.ausmini.com/forums/viewtopic.php?f=2&t=80554
Author:  BBY755 [ Sun Mar 03, 2013 4:30 pm ]
Post subject:  Window winder jammed....any easy fix?
Did a search for this but no luck....I used to be able search properly but since the latest crash, not working as before...
My drivers side window winder now jammed - with window up. Took off door card and had a look at the regulator after taking the 4 mounting screws off.
The winder is jammed and can't even work out how it should work internally to engage the winder half cog.
Any ideas that may help?
Thanks in advance.
Author:  Harley [ Sun Mar 03, 2013 5:29 pm ]
The spring should be visable, does it all look in one piece?
Author:  BBY755 [ Sun Mar 03, 2013 5:52 pm ]
Yep,
Looks complete and has tension.Have taken tension off lever but winder seems jammed.Saw the how to from the workshop manual and the how to for a clubby door, and will take the lot out including the quarter window and main glass if needed, but hoping something easy to fix with winder still in door.....
Thanks
