It is currently Thu Jul 17, 2025 3:03 am
 Post subject: HIF 44 v Twin Su
PostPosted: Mon Mar 04, 2013 3:02 pm
Hi All
Im after a bit of advice and opinions on which way is best to head. I have a bog std A+ 1275 with a HIF 44 originally with a K&N filter and a BCE needle which worked ok considering it hasnt been on a dyno to get set up properly. Im finding after now moving up to the hills its a bit flat from low to mid range whilst getting back on the throttle when under load. Have done the usuall things of playing with dashpot oils and giving the spring a bit of a stretch. So what im wondering is it worth biting the bullet and getting it on a dyno with the hope of improving the issue or would a pair of 1,1/4 SU carbs be a better bet for this sort of driving around hilly windy roads any advice would be great
66 Van 1275
69 K Sedan
69 K Van Teabag
66 austin Countryman
68van
PostPosted: Mon Mar 04, 2013 3:04 pm
I'd dyno it first.
