It is currently Tue Jul 22, 2025 4:00 am
PostPosted: Mon Mar 04, 2013 12:06 am
Hi guys
Anyone have details on the wiring for the a/c it is the all under dash type with the sandan controller
Thanks
PostPosted: Mon Mar 04, 2013 4:27 pm
What year and model Rover? I have a Haynes service and repair manual covering from 1969-2001.
PostPosted: Mon Mar 04, 2013 4:48 pm
It'll be for the upto 1991 models. They wend EFI after that.
The circuits for the 998cc cars with AC are rare, can't say I've noticed one before.
PostPosted: Mon Mar 04, 2013 4:50 pm
I had that in my mini, what do you need to know?
Cheers Pete
PostPosted: Tue Mar 05, 2013 1:18 am
Basically need to know what goes where... Lol
Starting from scratch
PostPosted: Tue Mar 05, 2013 12:05 pm
As far as I remember it's all pretty simple. . .signal from switch goes through the gas pressure sensor then into a relay. . .relay triggers the compressor and, I think, an idle-up solenoid on the carb.
PostPosted: Tue Mar 05, 2013 9:47 pm
Like I said I have the manual for that, Blunder what year and model car do you have :?:
 Post subject: A/C wiring.
PostPosted: Wed Mar 06, 2013 6:08 am
[quote="PetenSoaf"]As far as I remember it's all pretty simple. . .signal from switch goes through the gas pressure sensor then into a relay. . .relay triggers the compressor and, I think, an idle-up solenoid on the carb.[/quote]
and the condenser fan. This is very important to keep the heat and pressure down.
"Let us remove your "SHORTS"
