It is currently Tue Jul 22, 2025 7:59 am
PostPosted: Tue Mar 05, 2013 6:47 pm
(Copied and pasted from my WTB thread in Wanted section)
Hi there.
I have a slight clutch issue....
Over time, it seems to get air bubbles in the line; and putting my foot to the ground in the clutch does nothing.
I have bled it via the arm thing; in above the gearbox. It worked for about a week; and then got full of air.
Where would this problem be originating from?
I need to buy this faulty item!!!!
Tis a leyland Clubman 998cc
Dan.
PostPosted: Wed Mar 06, 2013 4:57 pm
I would put a new slave cylinder and a new flex hose on it.
If the slave cylinder is starting to rust inside, it will take in air.
And you should replace the hose as matter of course.
You're so square
Baby I don't care
