It is currently Thu Aug 21, 2025 5:02 am
 Post subject: Ignition Barrel
PostPosted: Sat Mar 16, 2013 8:21 am
Occasionally to start up the car, I have to jiggle the wheel/key as I turn it over to keep the electrics going! Faulty ignition barrel? Loose wires? When she runs she's all good.
(And it's not jiggling the wheel to 'unlock' the ignition, that's fine!)
1975 Clubman
1152cc, 40dcoe weber, RE83 cam, GRed head.
PostPosted: Sat Mar 16, 2013 8:51 am
I currently have the same problem in my 77..
I duct taped the back of the barrel up and it works fine.
But the problem is just a worn out barrel..
The bottom of them eventually comes loose and the contacts don't work aswell.
Simplest way to fix it is a new steering column because swapping just a barrel is a pain.. A place that does that kind of thing may be able to fix it.
But I'm just chucking a whole column in..
Cheers, Rhys
1977 Leyland Mini Van - Sold
 Post subject: How to fix it.
PostPosted: Sat Mar 16, 2013 12:39 pm
To fix it you buy a complete Modification Ignition switch/Steering lock from me. I have new ones. Email me for a picture and price.
"Let us remove your "SHORTS"
Users browsing this forum: No registered users and 120 guests
