It is currently Thu Aug 21, 2025 1:42 am
PostPosted: Tue Mar 12, 2013 3:15 pm
Just fitted a set of Maniflow free flow extractors with a single box rc40 exhaust to the 998. Where does the bracket on the bottom of the extractors bolt to? It looks like it should bolt to the bottom bolt of the output shaft cover but doesn't line up properly. Or does it bolt somewhere higher up?
1963 Morris 850
PostPosted: Tue Mar 12, 2013 6:34 pm
Keep tapping it up, it will eventually need to line up with the side cover.
PostPosted: Tue Mar 12, 2013 6:56 pm
Are these the single piece extractors or two piece?
I have the single piece and threw the bracket in my box of useless parts.
PostPosted: Tue Mar 12, 2013 8:26 pm
Yeh there the single piece. Are they prone to cracking if that bottom bracket isn't fitted?
1963 Morris 850
PostPosted: Tue Mar 12, 2013 8:34 pm
I bent the bracket until it lined up with the bottom bolt on the drive shaft cover
You may need a slightly longer bolt otherwise if too short they will strip the thread easily
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Tue Mar 12, 2013 8:50 pm
I have two sets fitted. Done several 1,000 miles, including the Hay motorkhana – no cracks yet.
PostPosted: Wed Mar 13, 2013 2:29 pm
Great. Thanks all.
1963 Morris 850
 Post subject: As usual
PostPosted: Thu Mar 14, 2013 8:10 pm
I think some fit things incorrectly and because the part fails they call them crap. Maniflow extractors are very well made in my books better than any I bought made locally.
"Let us remove your "SHORTS"
PostPosted: Thu Mar 14, 2013 8:16 pm
I have seen a few sets of these freeflows crack at the top Y join, usually because the motor was moving about (engine steady probs) + the bottom bracket not fitted.
I doubt they would crack if you have a remote shift box (not rodchange).
PostPosted: Thu Mar 14, 2013 9:09 pm
Yeh box is remote shifter and I also replaced engine steady bushes both sides as well as engine mounts. Engine doesn't move at all so should be all good.
1963 Morris 850
Users browsing this forum: No registered users and 366 guests
