It is currently Fri Aug 01, 2025 9:51 pm
PostPosted: Thu Mar 07, 2013 9:21 am
Set of disc brake conversions weight 30kg - just thought I let you know.
David L
PostPosted: Thu Mar 07, 2013 9:23 am
Thanks :?
1964 998cc Cooper
1971 Mini K x 2
1972 Clubman GT
PostPosted: Thu Mar 07, 2013 9:32 am
That sounds pretty heavy.
A complete vented disc drive setup should be about 25kg for the pair (no drive shafts).
What are you weighing?
PostPosted: Thu Mar 07, 2013 10:58 am
Asked Minii Sport their shipping weight - that's what they quoted
David L
PostPosted: Thu Mar 07, 2013 11:07 am
They Probably mean it fits into the Up To 30KG bracket :idea:
PostPosted: Thu Mar 07, 2013 11:22 am
Only talking 5 kg diff - sheesh
David L
PostPosted: Thu Mar 07, 2013 11:45 am
For what it's worth, I recently got a disc brake kit from minispares uk, and it was 478ukp plus 156ukp to ship. Unsure of measured/quoted or actual weights, although this did have alloy calipers, not cast iron jobbies.
Turned out at just about $1000.
Matt
'68 Deluxe w/Metro engine
PostPosted: Thu Mar 07, 2013 2:39 pm
Matt
Was that a 7.5"kit? or 8.4"? I'm hunting through as many places as I can find trying to get the best deal I can.
Can I ask how comprehensive the kit was?
PostPosted: Thu Mar 07, 2013 4:20 pm
It was this kit. I must have got it on special.
http://www.minispares.com/product/Class ... 0to%20shop
It included just about eveything, but BYO steering arms, bolts and I think locating washers. And BYO brake hoses.
I didn't need CV joints, but got them in the kit.
As others on this forum have mentioned, the ball joint kits don't have enough shims, so order extras. Goodness knows why.
Matt
PostPosted: Fri Mar 08, 2013 5:06 pm
"...Only talking 5 kg diff - sheesh.."
Try that on the man at the airline check in desk.... at around 50 Euro a KG javascript:emoticon(':shock:')
I managed to get a refund (around $700!!!) from Qantas when I got home but many heated words were spoken.....
Cheers, Ian
PS Check your ticket carefully. These days a Qantas ticket is not a Qantas ticket (despite what the ticket actually says) unless there's a kangaroo on the tail.... And your baggage allowance is determined by who's name is on the aeroplane.... and it can change if you use different brands for different legs of a UK/Oz flight....
