It is currently Sun Aug 17, 2025 5:38 pm
PostPosted: Mon Mar 11, 2013 2:24 pm
Hi again!!
Thought I would do the quick job of putting the timing cover on today and, as is always the case a small job turned big!! Went to put the small 1/4" bolts on and 4 out of 6 of them stripped the thread in the backplate. Thought I could maybe get away with a nut on the back but the one at the very top and 2 on the bottom are really fiddly and tight...is drilling them out and tapping them to the next size an option??
PostPosted: Mon Mar 11, 2013 2:42 pm
I'd think the clearance in the "lip" of the timing cover would make it awkward with a larger head.
I'd go with helicoil (or similar) to repair to original size.
Check your bolts before using - if stripped 4 of 6 - sounds like someone may have been hamfisted in the past. Better to replace than try and using dodgy ones.
PostPosted: Mon Mar 11, 2013 2:49 pm
Not thick enough for a reliable helicoil.
I tap them to 5/16 UNF and shorten some screws to suit. Do it in situ, then drill the cover holes to 8.5mm.
I had to do one last week. :wink:
[edit] There is clearance in there for 5/16 bolts, some are that size already.
Last edited by drmini in aust on Mon Mar 11, 2013 9:04 pm, edited 1 time in total.
PostPosted: Mon Mar 11, 2013 8:33 pm
Ok great..thanks for the replies!
Users browsing this forum: i got a mini and 272 guests
