Timing cover thread's stripped https://www.ausmini.com/forums/viewtopic.php?f=2&t=80668 |
Author: | spfh84 [ Mon Mar 11, 2013 2:24 pm ] |
Post subject: | Timing cover thread's stripped |
Hi again!! Thought I would do the quick job of putting the timing cover on today and, as is always the case a small job turned big!! Went to put the small 1/4" bolts on and 4 out of 6 of them stripped the thread in the backplate. Thought I could maybe get away with a nut on the back but the one at the very top and 2 on the bottom are really fiddly and tight...is drilling them out and tapping them to the next size an option?? |
Author: | MINImal effort [ Mon Mar 11, 2013 2:42 pm ] |
I'd think the clearance in the "lip" of the timing cover would make it awkward with a larger head. I'd go with helicoil (or similar) to repair to original size. Check your bolts before using - if stripped 4 of 6 - sounds like someone may have been hamfisted in the past. Better to replace than try and using dodgy ones. |
Author: | drmini in aust [ Mon Mar 11, 2013 2:49 pm ] |
Not thick enough for a reliable helicoil. I tap them to 5/16 UNF and shorten some screws to suit. Do it in situ, then drill the cover holes to 8.5mm. I had to do one last week. ![]() [edit] There is clearance in there for 5/16 bolts, some are that size already. |
Author: | spfh84 [ Mon Mar 11, 2013 8:33 pm ] |
Ok great..thanks for the replies! |
