It is currently Mon Aug 18, 2025 10:24 pm
Post new topic Reply to topic  [ 36 posts ]  Go to page 1, 2, 3  Next
 Post subject: Subframe Mounting ?
PostPosted: Wed Dec 19, 2012 11:06 am
Die Die Die!!
just a quick question,
when i pulled my moke subframe out it had two long bolts sticking up out the top of each tower for the mounts
however my modified subframe doesnt have any bolt.
does that mean its the centre bolt type ? and if so, will the Moke crossmember need a reinforcing plate since it was designed for the 2 bolt type ?
Nick
PostPosted: Wed Dec 19, 2012 11:23 am
There were 3 top mounting systems:
each side-
2x studs with nuts
2x bolts
1x BIG bolt (and rubber mounts between subframe and body).
The big bolt was only used on UK subframes from ~1976 on, so we never got them here. Unless your modified subby is out of a Rover..
Yes if you want to mount a single bolt subby in an Oz Mini or Moke, the centre hole needs a tube in there for reinforcement.
PostPosted: Wed Dec 19, 2012 11:44 am
The studs can come out of your other frame...........
PostPosted: Wed Dec 19, 2012 12:21 pm
Die Die Die!!
each side-
2x studs with nuts
2x bolts
so the other subframes have the threads for the big bolts ?
PostPosted: Wed Dec 19, 2012 12:22 pm
Die Die Die!!
ill try and tap them out, i already bought some body to subframe rubber mounts for the big bolts.. might just use them..
PostPosted: Wed Dec 19, 2012 12:23 pm
If this is for your conversion moke it doesn't have the bog bolt hole.
PostPosted: Wed Dec 19, 2012 12:27 pm
Die Die Die!!
so it looks like im tapping out the bolts then.. haha
PostPosted: Wed Dec 19, 2012 12:31 pm
Shouldn't be hard.
Remove the studs from the old frame with either 2x 5/16 unf nuts on the top or multigrips of you must, then tap the holes in the subframe out 3/8 unf and put the studs in - I'd suggest a thin smear of copper grease to stop it rusting, not that you'd have that problem up there.
Captive plate on the top and some new 5/16 nuts and you're done.
Second thoughts - see if you can get some long 3/8 bolts to fit. They'd be better suited to your upgrade.
PostPosted: Wed Dec 19, 2012 12:42 pm
Bolts are a better idea, they come out- whereas the 4 studs often get bent when you drop the subby down.
PostPosted: Wed Dec 19, 2012 4:46 pm
Die Die Die!!
the two bolts seem to be fixed to a plate which is wedged between the inside of the tower and the round plate that the the rubber cones sit in
PostPosted: Wed Dec 19, 2012 5:27 pm
Yes they are studs ie, they have a thread on the other end so get yourself a stud extractor or use two nuts as Harley said an get them out and fit them into the other frame.
PostPosted: Wed Dec 19, 2012 5:57 pm
Or, just get 4 of the right bolts and use these. Mini King probably has some still.
Oz Minis used both systems, I'm not sure what the split was, studs vs bolts.
Mini King's parts book shows both bolts and studs were used on dry suspension and hydro, on Mini and Moke.
PostPosted: Wed Dec 19, 2012 6:09 pm
I tried to put bolts in my car but the crush tubes wouldn't allow them to fit.
Either the tubes were too small, or they were too close together.
PostPosted: Wed Dec 19, 2012 6:14 pm
Oh I'm not disagreeing sorry just explaining what they are, I use bolts, studs suck
PostPosted: Wed Dec 19, 2012 8:49 pm
Die Die Die!!
so if i have studs (they look like bolts to me..) what do bolts look like ?
Users browsing this forum: No registered users and 315 guests
