It is currently Wed Jul 30, 2025 6:56 pm
 Post subject: Engine Help!
PostPosted: Wed Jun 15, 2005 12:12 pm
Okay, i did something stupid and im not sure why, but anyway once i put my head back on i tightened up the nuts and whatnot but not tight enough, poured cooland in the radiator and it leaked out the thermosat housing, not too bad i thought just needa get some gasket stuff to seal it up properly. well today i removed the head and low and beho.ld the coolant has leaked inbetweeen here and the block, and into where the puushrods sit. will i have to strip down my engine to clean all this crap out or will i be able to use some sort of flush to get the remaining coolant out because i think it has mixed with the remains of the oil...i did not sart the engine by the way. :shock: cheers guys, i wish i thought before i did things :oops:
I have a problem.. apparently
PostPosted: Wed Jun 15, 2005 12:36 pm
Hmm..that's a tough one...good thing you didn't start it.
Did you use a torque wrench to tighten the head?
I'm not sure what the deal is mixing oil with coolant...
I'd drain the oil for a couple of days maybe, refill, run it up to temp and drain it again..maybe repeat a few times until your confident it's clean..
PostPosted: Wed Jun 15, 2005 12:38 pm
nah i didnt use a tourque wrench i was trying to find one, and i got sick of seeing the green bottle sitting around. i wont be starting for a while so i might leave the head off and let some of the coolant evaporate out, thank you for your help, i was dreading the pulling of the engine apart! :(
Take off the inspection plates and put a chux into each cam follower and soak up the coolant if you get most of it you should be ok.
steve
PostPosted: Wed Jun 15, 2005 7:51 pm
I would drain the oil- coolant is heavier than oil, and if any is sitting in there the pump will pick it up, and it won't help the bearings.. :cry:
PostPosted: Wed Jun 15, 2005 9:24 pm
thank you guys, hopefully it all works out :)
PostPosted: Wed Jun 15, 2005 10:52 pm
:roll: Duffer...were you watching the TV while you were doing it or did a Nice girl walk by :lol: We all do Silly Things . :wink:
Is the motor in or out ...Drain it refile with oil (cheap Big W stuff) and re drain it.
If you have not turned the motor over she should be fine ...just dribled
PostPosted: Thu Jun 16, 2005 11:49 am
nah i just never think hahaha, the motor is out, and i got some cheepy oil to run through when she goes back in ;) thanks again guys, im so glad i didnt have to pul it down.
