It is currently Tue Aug 19, 2025 3:37 am
PostPosted: Tue Mar 12, 2013 1:55 pm
I have never had a brake booster on any of my disc brake minis previously. The one I have now came with one fitted and is getting the vacuum from the manifold, which was a goose neck style for a Dellorto. The car is running 8.4 Discs. I am now fitting a Russell Engineering manifold which doesn't have the option for the vacuum.
I was wondering about opinions on whether the booster should be retained or I should not fit it?
1975 1310cc Street Mini Custom
1974 Leyland Mini daily driver
2008 Cooper S R55 Clubman
PostPosted: Tue Mar 12, 2013 1:58 pm
As you have the servo already I'd just tap the manifold somewhere to suit. You only need to do 1 side. Unless you want to do the other port as well, and run a PCV valve into it. Works for me... 8)
PostPosted: Tue Mar 12, 2013 2:43 pm
Boosters are personal choice.
Some people like them, others dont.
I haven't got one in my car which suits me fine........for the first 30 minutes of driving.
:lol:
That said, I wouldn't run hard / sport pads without one though.
PostPosted: Tue Mar 12, 2013 3:31 pm
I run S brakes with Greenstuffs and no booster, and to me it's fine. It pulls 1.0G on a brake test.
But I let my Bogandore neighbour drive it once and he said f***, where's the brakes!! :lol:
PostPosted: Tue Mar 12, 2013 4:14 pm
If I tap in a vac line will it affect the flow rate of the manifold? I don't mind a hard pedal. I am thinking of going non boosted and if I don't like it then add the booster later.
The last disc brake set up was Cooper S non boosted. Seemed alright for the year or so I had the Mini for as a daily driver.
PostPosted: Tue Mar 12, 2013 6:29 pm
Nope it won't affect flow under power. It only pulls vacuum when you have your foot on the brakes.
The vacuum is then held in the booster by a check valve at its hose connection.
PostPosted: Tue Mar 12, 2013 7:08 pm
That's interesting/good to know. The performance test here for a low volume modified vehicle (what you guys call 'engineered') is .65G, with 68kg force on the pedal causing maximum breaking effect.
Users browsing this forum: No registered users and 314 guests
