It is currently Wed Aug 20, 2025 8:26 pm
 Post subject: pulsar dissy module...
PostPosted: Tue Mar 12, 2013 11:42 pm
hi i have a hot 1160 that will get the pulsar dissy treatment.
i have both the d83 and d85 pulsar dissy
both modules are stuff which one shall i use ?
please shed some light im a little lost on which one to keep and where to get a decent priced module
thanks noobie
Fried Ricer
PostPosted: Wed Mar 13, 2013 6:47 am
If both modules are gone, I'd just get another dizzy. I realise they are probably thin on the ground over there, but surely that is less trouble. As to which I can't recall what I used on my 1293 - Drmini advised me which one. It is also important to service it greasing an internal shaft as I recall. Again, Drmini should be able to advise. If he doesn't respond here, maybe send him a PM.
One of the troubles you may face is that in order to buy a module, the Nissan stealer may insist on having a VIN number "for their system!"
I had a similar problem trying to buy Honda parts when the Honda dizzy was the gun mod (before the pulsar ones came along). I only had the distributor (with me as it happened) and because I didn't have the details, they were unable or unwilling to exercise their grey matter at all.
PostPosted: Wed Mar 13, 2013 8:05 am
Check with `convertible mini' (Tony) he may have a Pulsar module.
I sold my last spare a while ago.
The Hitachi modules are pretty reliable, I have never yet killed one.
 Post subject: Pulsar Module
PostPosted: Thu Mar 14, 2013 8:17 pm
I have got some stock Pulsar Modules. I will need an emailed Picture for correct identification as there are a couple of different variations with these modules. And remember.... If you have a problem that is causing the modules to cook or blow, fix it first as I give you no warranty on modules sold. Some people replace a module without finding out why it blew in the first place. Electronics blow faster than a fuse. Too much current drawn by the coil and POP goes the module.
"Let us remove your "SHORTS"
Users browsing this forum: Bing [Bot] and 330 guests
