It is currently Tue Aug 19, 2025 10:28 pm
 Post subject: Weber 40 v Twin HS4?
PostPosted: Wed Mar 13, 2013 7:45 am
I may have the option on a mint 40mm Weber. Barney is a mild 1293 and I'm wondering if I should go down the Weber route. A bit of Googling suggests it may be a slight step backwards in terms of performance, but I love the gurgling noise. :twisted:
Thoughts?
PostPosted: Wed Mar 13, 2013 8:01 am
If it's cheap I'd buy it and try it. You can always sell it on if you don't like it.
Benefits-
Stays in tune (no linkages in there between the throats, no needles to wear, no throttle shaft wear)
Weber `music'
Easy to remove/replace (5 mins or less, try that with yer twin HS4s on the manifold with the heatshield)
Throttle response
Downsides-
Fuel economy, but not too bad if you jet it for the road using an A/F meter.
Limited manifold choices without a Weber box in the firewall (PLEASE don't buy a Lynx tall gooseneck one)- a Redline/Warneford 3005 is the best available that fits with a filter.
PostPosted: Wed Mar 13, 2013 8:04 am
Doc, it's like your sitting there waiting for my inane questions!
Dad's just picked up a 45 for the Major and he will have a 40 sitting there. Yet to negotiate on it. Not sure what chokes its running either.
Stay tuned (pardon the pun).
PostPosted: Wed Mar 13, 2013 8:15 am
IMO a 40DCOE is a bit small for a 1275, unless it's near stock. But your 1293 isn't modded much, the cam is just a Wade or Tighe 104 with Corolla rockers, and it still has 1100S sized inlet valves..
PostPosted: Wed Mar 13, 2013 8:17 am
So it would be comparable to the twin HS4s at the moment. I'm really just chasing the "music", but I don't want to give too much away in terms of performance.
Not too worried about fuel consumption, even in view of my recent efforts (running out of juice twice within a week).
ER
PostPosted: Wed Mar 13, 2013 9:28 am
The Mini King
I have a second hand weber 45dcoe with a red line manifold and linkages Carby set up;
idle jet 50FD air corrector 85FP acc squirter 45 venturi 45 choke 36
145 jet 180 bleed F15 emulsion
Kev can advise you of a better set up, but this is how it is set up at present
If of any use give me a call if You Like
I should add that I am not a weber fan for street cars, however that is My opinion,
and as My Dad always said opinions are like faces we all have one and they are all
different
PostPosted: Wed Mar 13, 2013 2:23 pm
Cooper_Matrikon wrote:
even in view of my recent efforts (running out of juice twice within a week).ER
:lol: Where's MiniDave when you need him ? :wink: :lol:
Users browsing this forum: No registered users and 471 guests
