1100 S harmonic balancer https://www.ausmini.com/forums/viewtopic.php?f=2&t=80697 |
Author: | Kennomini [ Wed Mar 13, 2013 4:25 pm ] |
Post subject: | 1100 S harmonic balancer |
Is it safe to use a small bore harmonic balancer on an 1100S engine ![]() The engine will be either 0.40 or 0.60 thou over bore and crank is large journal 0.10 or 0.20 thou over on the journals and large journal rods. Or should I get a cooper S balancer? |
Author: | TheMiniMan [ Wed Mar 13, 2013 5:39 pm ] |
its the same part, same part number too |
Author: | drmini in aust [ Wed Mar 13, 2013 6:24 pm ] |
Just make sure the rubber bonding is OK if it's s/h. Run a razor blade around the back to clean it off flush, if rubber isn't cracked then it's a good 'un. ![]() |
