It is currently Wed Jul 23, 2025 11:34 am
PostPosted: Tue Jun 14, 2005 8:09 pm
Got a question about the twin tank set up. I'm having trying to map out what i'm thinking so if it doesn't make sense its not intentional.
If i just use the standard speedo that shows the fuel level am I getting a correct reading from what is left in both tanks? Meaning - If the level is reading half have i got half of the capacity of both of the tanks or half of the capacity of the tank with the sender on it?
I guess the real question is - do the tanks level out? If i fill up the left tank and not the right will it say i have half capacity left, which is not really the case?
Whilst typing I have raised another concern. Because Striped is going to be fool injected and if the tanks don't level out that creates the possibility of air getting in the lines. F/ing the pump and.or the injectors.....
Anybody able to shed any light?
PostPosted: Tue Jun 14, 2005 8:14 pm
I think the theory is they are supposed to level out through the balancer pipe..but it takes a while..
Sorry, not much help..
PostPosted: Tue Jun 14, 2005 8:17 pm
Mine do.. it takes a little bit after filling before they are the same..
PostPosted: Tue Jun 14, 2005 8:20 pm
On level ground they level out. If car is tilted they level, but will not be equal- fuel gauge reads whatever level in LH tank is.
Note: If parking car severely tilted,
1. You want good caps that seal. :lol:
2. The breather pipes on the top of tanks must each cross to other side of car. If not it can drain to lowest tank, then siphon fuel to ground.... :shock:
PostPosted: Tue Jun 14, 2005 8:25 pm
Mini Mad wrote:
balancer pipe..
Balancer pipe hey? which one is that? The one at the bottom that goes into the T piece?
And if they be balancing does that mean the return line from the fuel rail can just go into one of the tanks?
Can you elaborate on this Doc? I don't quite get what you mean.....Note - There are no pipes coming from the top of either of my tanks.
PostPosted: Tue Jun 14, 2005 8:32 pm
The `balance pipe' pipe is the RH feed pipe to tee.
Yes the return can go back to 1 tank, but it might be an idea to make RH tank's feed pipe bigger.. :wink:
PostPosted: Tue Jun 14, 2005 8:35 pm
Why's that?
PostPosted: Tue Jun 14, 2005 8:36 pm
Look inside boot- there is a spud fitting right at top of each tank pointing to centre of car. There should be 2 black pvc? pipes on there, on an S, they cross each other under parcel tray..
Then they exit thru boot floor, near battery cable and fuel line to pump. :wink:
On a single tank Mini, it exits near the fuel line, doesn't go across the car.
Must be smelly in your car with no breather hoses.. :lol:
PostPosted: Tue Jun 14, 2005 8:37 pm
Why's that?
Because the return flow might exceed the balance flow (which is powered by gravity..) :wink:
PostPosted: Tue Jun 14, 2005 8:42 pm
Ok so i need to fit a pipe to connect the two black PVC's?
PostPosted: Tue Jun 14, 2005 8:44 pm
NO... they are separate, 1 from each tank, so 2 breathers thru boot floor.
Why's that?
You've lost me again. What's the difference between the return flow and the balance flow?
PostPosted: Tue Jun 14, 2005 8:45 pm
Oh, to atmo?
PostPosted: Tue Jun 14, 2005 8:52 pm
:idea: Yeah......... :wink: 8)
PostPosted: Tue Jun 14, 2005 9:16 pm
Why's that?
an den?
Users browsing this forum: kirby and 93 guests
