Rubber Cross Universals - Fitting Hassles
https://www.ausmini.com/forums/viewtopic.php?f=2&t=80750
Page 1 of 2
Author:  bnicho [ Mon Mar 18, 2013 8:31 am ]
Post subject:  Rubber Cross Universals - Fitting Hassles
Hi,
I am attempting to fit new rubber cross unis to the Shitbox Rally Van.
I popped off the top balljoint to get them into position, but I'm struggling to get the u-bolts slid home.
Any tips from someone who has done this job recently?
Thanks,
Author:  TheMiniMan [ Mon Mar 18, 2013 8:36 am ]
probably need to bend the u-bolts "in" a bit
they often spread while in use
Oh!!! & don`t over tighten them
& also i`d be setting the car up with the axles in their "in-use" height,,, so rest the car onto it`s wheels before you try to tighten the u-bolt nuts
Author:  minimy [ Mon Mar 18, 2013 4:37 pm ]
good advice matt :D
Author:  VulcanBB18 [ Mon Mar 18, 2013 6:09 pm ]
+1 for Matty's advice,
Also... new or old bolts? I've found some new bolts seriously wrong (far too wide)... so in went the old bolts with the new nuts :)
Oh... and... DON'T OVERTIGHTEN THEM!
sorry, just had to emphasise that point :mrgreen:
cheers,
Jacob
Author:  yorke2 [ Mon Mar 18, 2013 6:40 pm ]
Just squeeze them up in a vice till they fit neatly/easily, check them in the yoke before trying to fit the joint.
Brian
Author:  drmini in aust [ Mon Mar 18, 2013 6:57 pm ]
A viable alternative to the rubber joints is the QL5000 conversion, which uses a conventional Triumph TR6 Hardy Spicer joint with needle bearings, fitted with 4 nylon cups.
However I have it on good authority from a local distributor this week that Quinton Hazell in the UK (who supplied them) have recently gone broke and are in receivership. :cry:
If this is correct it will be a pity, they made & supplied quite a lot of Mini replacement parts.
[edit] see http://www.bbc.co.uk/news/uk-wales-nort ... s-21360719
Author:  bnicho [ Mon Mar 18, 2013 7:52 pm ]
Thanks guys, will give them a squeeze. Like a lot of things on this car, the original u-bolts were missing, so we are working with the new ones in the kit.
I have a set of the QL5000 conversion parts, but they are reserved for my Traveller. Watto and I agree they are not necessary for the Shitbox.
Author:  kiwiinwgtn [ Mon Mar 18, 2013 7:54 pm ]
Those QL5000 joints are heading towards Rocking Horse Poo material. I tried recently to find two new ones world wide with no luck. I got given one second hand and brought the a new joint with second hand cups. which wasn't cheap.
I my have to convert the next box I do to a hardie spicer set up as i have a couple of sets but only if I can find some side covers.
Author:  John Smidt [ Mon Mar 18, 2013 8:00 pm ]
cheers,
Jacob
The original New old stock U bolts are still avail From Mini King
Author:  bnicho [ Mon Mar 18, 2013 8:03 pm ]
John, do you have those plastic posts that go between the van tank and the body?
We need some of them quite urgently!
Thanks,
Author:  John Smidt [ Mon Mar 18, 2013 8:06 pm ]
Thanks,
Yes I have both types in stock , Send Me a PM if You Like
Regards
John
Author:  bnicho [ Mon Mar 18, 2013 8:20 pm ]
PM sent John.
Brett.
Author:  bnicho [ Tue Mar 19, 2013 5:06 pm ]
Problem solved the easy way.
Watto fitted the Unis today while I was at work!
8)
Author:  drmini in aust [ Tue Mar 19, 2013 6:06 pm ]
PM sent.
I can modify `meaty' Oz std sidecovers into Cooper S ones. I did some last year for Mini King.
Author:  TheMiniMan [ Tue Mar 19, 2013 6:57 pm ]
PM sent.
yes there are 2 castings for these,,, some are thicker around the seal & bush area & those are the ones that can be machined out to fit the bigger bush & seal into
ya cant really miss them when you have a look,,, we have quite a few thick ones here Doc , if you ever need some more,,, both the early type & the roddy type
