Lower Arm Pins
https://www.ausmini.com/forums/viewtopic.php?f=2&t=80754
Author:  _666_ [ Mon Mar 18, 2013 2:29 pm ]
Post subject:  Lower Arm Pins
have lower arm pins changed in design from aussie ones to UK ones ?
or perhaps early to late design ?
i just ordered one of these -http://www.minispares.com/product/Classic/Suspension/Front/Dry/2A4362.aspx?190201&ReturnUrl=/search/classic/lower arm.aspx|Back to search
for my moke.. and it doesnt fit my aussie subframe ? (the end will pass through the subframe)
am i missing a plate for the inside end ?
im under the impresion that it should fit against the subframe tight ?
any help would be much appreciated
Nick
Author:  Harley [ Mon Mar 18, 2013 2:32 pm ]
Pins are all the same, I'd say your frame might have been modified.
Can you post a pic of the subframe where it fits?
Author:  _666_ [ Mon Mar 18, 2013 2:45 pm ]
thanks for the speedy reply harley, i must be half asleep and half a complete idiot..
i was test fitting the pin in the upper arm hole :oops:
Author:  TheMiniMan [ Mon Mar 18, 2013 3:00 pm ]
there are 2 pins, early & late
one had a flange , or shoulder-plate (for want of a better description) & the other had no flange
either work fine & are totally interchangeable
Author:  _666_ [ Mon Mar 18, 2013 3:13 pm ]
Having now found the correct hole when inserted the pin doesn't have much meat on the end, only just enough to get the but on and that's without a spring washer, will this get better as I tighten the nut?
Author:  Harley [ Mon Mar 18, 2013 3:22 pm ]
The pin changes from 3/8" thread to 1/2" shank.
The hole is 1/4" deep, when the shoulder bottoms out there should be enough thread poking through the other side for a nyloc nut or a spring washer and normal nut.
If there's not enough thread, just use a normal nut with loctite.
Author:  _666_ [ Mon Mar 18, 2013 4:03 pm ]
ok they are now fitted.. only just just comes flush with the end of the nut, and thats with it done up to to a point where i wouldnt want to do it tighter for fear of bending the subframe
